Results 1 to 17 of 17
  1. hi there.
    i am trying to do a real simple thing. i have an ISO Image of a Full bluray 3D Title.
    i want to make 1:1 copy
    to Extract just the main Movie to an MKV file. - which will also be 3D.
    using Makemkv. i am choosing just the main movie like so:
    at the end of the process - i get a mkv file that is 2d. not 3d.
    Why is that ?
    Apr 2014
    Nederland
    Because it probably isn't a 3D Bluray. A 3D BluRay in MakeMKV should look like this:
    Mpeg4 is the main video stream and Mpeg4-MVC-3D is the second stream.
    What you can do to double-check:
    - unpack/digitaly mount your disc on your computer, (I use Virtual CloneDrive)
    - Check this folder: F:\BDMV\STREAM\SSIF
    If there is a SSIF folder with a .ssif file, it's a 3D BluRay. If not, it's just a 2D BluRay.
  3. Yes I have that ssif folder
    Apr 2014
    Nederland
    hmmmm.... strange.
    - What version of makeMKV are you running?
    - Can you make a screenshot of the SSIF folder and a screenshot of the "Title information" of the movie from MakeMKV?
  5. Version of makeMKV:
    SSIF folder:
    What is screenshot of the "Title information" of the movie from MakeMKV?
    Apr 2014
    Nederland
    The text on the right is title information. Most of the times, the source file name is the same as the SSIF file name.
    Apr 2014
    Nederland
    You can also try putting the ssif file in tsmuxer and creating a new iso with only the movie and open that file in makemkv.
  8. @arthurm
    screenshot: (source file name is the same like the one in the ssif folder)
  9. Originally Posted by arthurm View Post
    How do i choose only the 3D version ?
    Apr 2014
    Nederland
    If you want a 3D version, you'll have to select all of the video stream (MVC&H.264). You can select the audio you want. Be sure that you select "Create ISO".
  11. i give up. just gonna download 3d mkv's
    Apr 2014
    Nederland
    But doesn't MakeMKV recognize the new 3D ISO? Does is still not say anything about MVC?
  13. just loaded another iso image. to makemkv. this time i see the mpeg4 3d select it
    after it's done i open it and there is just a 2d version mkv
    Apr 2014
    Nederland
    Ah, but you can't just play the 3D MKV. It's not as simple as a SBS or OU MKV. you'll have to install special players like stereoscopic player.
    May 2023
    Poland
    hello,
    how to make a MKV in format SBS or HOU from ISO image . . .
    1. MakeMKV - will never do that ( just forget MakeMKV )
    2. install virtual BD ( recomended freeware : Virtual Clone Drive )
    3. install frame tool : Avi Synth Plus ( freeware )
    4. install converter : bd3D2mk3D ( freeware )
    Now follow simple steps :
    1. mount ISO Image as a drive using Virtual DB
    2. run bd3D2mk3D :
    - open this virtual drive as source 3D
    - choose codec ( AVC or HEVC ) from Settings
    - choose stereoscopy mode ( HOU or SBS ) from Options
    - press "DO IT" to start converter
    ... and in the end - don't forget to smile
    Feb 2006
    England
    Originally Posted by eerrttyy View Post
    hello,
    2. run bd3D2mk3D :
    I have never seen a reply on ANY message board come 8 years later! This has to be a record!
    Jagabo, please do not reply to this post. Thank you.
  17. 8 years, yes, it's funny. But, as the author of BD3D2MK3D, I appreciate this late reply !
    r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
    - BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
