  1. I have looked around the forum for a while and can't find a fix for my problem. What I am trying to do is, I have MP4 files that I have purchased and I have DL subs from a subtitle site that gradually go out of sync. I'm guessing the files are pal they are Spanish from Spain. I have tried a few programs (subtitle workshop, subtitle creator) but they did not fix the problem maybe I did something wrong. I used input 25 and output to 23.97 and 29.97, neither worked. Is there an easy way to do this.
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Post a mediainfo report of the MP4 file. Look for another source for your subtitle.
  3. Selection (1080p HD).mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 1.59 GiB
    Duration : 44mn 44s
    Overall bit rate : 5 092 Kbps
    Movie name : Natural Selection
    Album : Orphan Black, Season 1
    Album/Performer : Orphan Black
    Part/Position : 1
    Part/Total : 1
    Track name/Position : 1
    Track name/Total : 12
    Genre : Sci-Fi & Fantasy
    Description : Sarah, a streetwise hustler on the run from a lifetime of bad decisions, witnesses the suicide of a
    Recorded date : UTC 2013-03-30 07:00:00
    Encoded date : UTC 2015-06-11 03:44:36
    Tagged date : UTC 2015-06-11 03:48:22
    Video
    Format : AVC
    Format profile : High@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : avc1
    Duration : 44mn 44s
    Bit rate : 4 961 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 23.976 fps
    Maximum frame rate : 42.814 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.100
    Stream size : 1.55 GiB (97%)
    Language : English
    Encoded date : UTC 2015-06-11 03:46:18
    Tagged date : UTC 2015-06-11 03:48:17
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 44mn 44s
    Duration_LastFrame : -13ms
    Bit rate mode : Variable
    Bit rate : 127 Kbps
    Maximum bit rate : 194 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 40.6 MiB (2%)
    Language : English
    Encoded date : UTC 2015-06-11 03:44:37
    Tagged date : UTC 2015-06-11 03:46:18
    Text
    Format : EIA-608
    Muxing mode : Final Cut
    Codec ID : c608
    Duration : 44mn 24s
    Bit rate mode : Constant
    Stream size : 0.00 Byte (0%)
    Language : English
    Encoded date : UTC 2015-06-11 03:48:18
    Tagged date : UTC 2015-06-11 03:48:21
