Hello
I am making short videos (1 to 2 minutes). These videos are steps to follow to solve math problems for teaching use.
Would it be possible to have a video player that pause at every chapters of a mp4 video ? We would have to press play again to see the next step until the video pauses before the next step.
Any idea on how to do this ?
Thank you
Results 1 to 11 of 11
Share lossless video into parts. Player will stop and then you can go to the next part. Track chapter can be discarded.
Thanks for your answer.
I can not split the videos into many files, I would prefer a solution that keeps a single video file... -
You can probably use Adobe Flash or Edge Animate.
However, breaking the file down into sections, which you rejected earlier, gives you more options, simpler coding and can provide an identical user experience. -
Thank you all !
I have more than 40 small videos explaining math problems step by step. That you make 200+ files !
I want the video files to be playable by ANY media player without the chapters bonus because teachers are going to use this from different computers. And I would like to offer an option with a specific media player or way of doing things that makes it possible to pause the video between each steps.
I hope im clear enough. Flash is the option I am considering right now.
Thanks again for your replies !
Not in the way that you described it.
Typically this would be done though HTML/ HTML5 through a web interface, or flash as described above, or a custom player/software
The only way I can see this working in a single file, is if you encode gaps between questions (video is actually playing, but it's a video of the last frame repeated) and you use chapter navigation buttons to advance (not through play and pause buttons). You could make it "VFR" (variable frame rate) to save bandwidth. This should work with all common players e.g. vlc, mpchc, potplayer etc.... -
200+ files.....
Yes and?
Are you familiar with the concept of folders?
Here is a solution bordering epic brilliance:
You copy all videos and cut up the copied videos and stick them in separate folders. That way teachers can chose to view the whole video and also the cutup versions.
Folders
Full videos
- Video 1
- Video 2
- Video 3
Cut up videos
- Video 1
- Video 2
- Video 3
Umm...a DVD or BD also makes sense in this situation.
Video pause initally when calling subtitles
By jsmith1299 in forum Blu-ray RippingReplies: 0Last Post: 1st Apr 2014, 18:19 -
I want to add chapters to a video on a DVD.
By Paulouk in forum Authoring (DVD)Replies: 26Last Post: 28th Feb 2014, 05:45 -
'Chapters' in video files?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 1st Jul 2013, 12:03 -
MPC-HC : audio does not pause when video pauses for H264 video
By kswartz in forum Newbie / General discussionsReplies: 3Last Post: 28th Jul 2011, 02:56 -
How can I mark events/chapters in video while I am capturing the video?
By CIguy in forum Newbie / General discussionsReplies: 16Last Post: 23rd Nov 2010, 22:04
