When I join segments to make one whole video (about 44 minutes long), I output the merged segments in MPEG-1 VideoCD mode. But when I did it, while it was compiling the segments (about 6 segments), the seconds for the video and audio portions didn't amount to the same. The video was roughly 2, 647.24 seconds while the audio was 2,647.27 seconds. I know this is a small number for being out of sync between the audio and video, but I want everything absolutely in sync. Was the seconds readout in error or is my audio and video out of sync for real? I didn't notice anything on the finished product but that could be because the difference between seconds is so small. But I was wondering what would cause the out of sync problem?
Plus, sometimes when I merge segments there is a "beep" where some of the segments are merged, what's that about?
Thanks.
PS -- I used the latest version of TMPGEnc in both instances.
It's a BUG
I've reported this to Pegasys-inc. Because it's in the 2.x and 2.x Plus versions.
Get TMPEG 12b from http://www.afterdawn.com
Also get the English patch from there.
Now you can merge and cut and your audio will be in sync.
kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net
How To Cut MKV Without Audio/Video Sync Problems
By Eva-Unit01 in forum Video ConversionReplies: 12Last Post: 2nd Mar 2011, 08:11 -
Video Audio Sync Problems
By Johnnysh in forum DVD RippingReplies: 11Last Post: 26th Jan 2011, 01:47 -
Sync problems after merging mkv video with mp3 audio
By billman1234 in forum Video ConversionReplies: 5Last Post: 29th Jun 2010, 15:00 -
Tmpgenc 3 audio video out of sync before encode
By marioval in forum Authoring (DVD)Replies: 8Last Post: 30th Jan 2008, 14:07 -
Trying to sync audio with edited video, problems with encode....
By Jensen in forum EditingReplies: 1Last Post: 5th Jan 2008, 08:20
