Hello!
I have a .mdx image that I can run perfectly using Daemon Tools. The problem comes when I burn that image into a DVD. I use Astroburn to do it. But when I try to run the program from the burned DVD it says: "the disk could not be verified to be a valid original". And the program wont run.
Why is that happening? (I know is not the original DVD) The mounted image works fine. Can I do something about it?
It's called copy protection or structure protection. Buy the original.
Thanks. So there's nothing I can do.
PS. I bought the original but I could not withdraw it from Customs (administrative issues). So i found the image on the internet and tried to make the DVD myself.
How to Extract an ISO Image without burning to dvd?
By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 02:07 -
AVStoDVD problem selecting thumbnail image
By slingo in forum Authoring (DVD)Replies: 11Last Post: 20th Jan 2015, 00:48 -
Problem with Image and Audio after using Handbrake!
By cari in forum DVD RippingReplies: 4Last Post: 3rd Jan 2014, 21:50 -
Still image Title Sequence showing as blank when burning to DVD.
By djlerman in forum Authoring (DVD)Replies: 0Last Post: 28th Jun 2012, 00:15 -
dvd burning error when make a bootable dvd image
By junian116 in forum Authoring (DVD)Replies: 1Last Post: 5th Apr 2011, 03:58
