Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
Results 1 to 9 of 9
    Jun 2015
    Romania
    Hi,
    I record video for a video blog I would like to know why the audio in the below clip sounds very full and rich like Howard Stern. Is it a characteristic of the person's voice or the kind of equipment used?
    Thank you
    https://youtu.be/pX8BXH3SJn0?t=5m11s
  2. Most important is close placement of the mic. Then a mic that can pick up low frequencies. Of course, the person's voice has to have low frequencies for the mic to pick up.
  3. Banned
    Oct 2014
    Northern California
    To get the effect use a good condenser mic, sit close to it, use a pop filter, and run a "radio voice" setting in your favorite voice processor.
    I personally like Nectar 2:
    https://www.izotope.com/nectar2
    Of course there is no problem making your voice sound good but do you really need that radio voice fakery?
  4. Originally Posted by caisys View Post
    ...very full and rich like Howard Stern.
    Specifically on Howard Stern, he uses a lot of compression on his mic.
    A LOT of compression.
    Jun 2015
    Romania
    To be honest, I probably do not need it
    The thing is I am new at this .. I am using an inexpensive clip on mic and recording the sound on my laptop. After that I use audacity for noise removal and add some effects I found on the internet.
    The results are not good. I was curious how they make the sound so full and rich on those shows. But if I can get the best out of my cheap equipment I would be very happy at the moment but since I do not even know how to diagnose what is wrong with the audio it is difficult to fix it.
  6. Banned
    Oct 2014
    Northern California
    Well the best bang for the buck is to get an inexpensive consenser mic.
    For instance a low end MXL with a good table mic stand and a pop filter.
    Something like this:
    http://www.bhphotovideo.com/c/product/859294-REG/MXL_Tempo_USB_Microphone_Bundle.html
    It sets you back about $150.
    Obviously it is not high end and there are many alternatives but you should be able to get a decent sound from it.
    With respect to noise removal, a quit room beats any noise removal program.
    A free hint for a quit room: go to the library and use one of those study boxes!
    Jun 2015
    Romania
    Thank you very much.
    Do you have any suggestions (a link to a guide or presets) for improving the sound of my existing vocal recording with audacity?
  8. Banned
    Oct 2014
    Northern California
    Why not upload a small slip so we can hear what your concerns are?
    Jun 2015
    Romania
    here is a sample:
    it is in arabic though but you will get the point
    http://we.tl/xWxLgl2Zud
    Thanks for your help
