We have mini DVD's from our camcorder Sony 91E. This was our first camcorder and there is no USB connection, so I copy the files from the mini DVD with the DVD burner onto the PC. I can play them with VLC, but I suppose it's better for the long term to convert them. I've download DVDVOB2MPG, converted to mpg, imported it to Sony Movie Studio Platinum, did some editing and burnt a DVD. The quality is a bit less than the original. Somebody advised Avidemux for converting.
My question is: is there a better way to convert the video's from the mini DVD's and what format? I like to burn DVD's (not BluRay), but also keep backups on an ext. harddisk. And we have PAL system here.
Results 1 to 10 of 10
There is no need to convert. Your camera creates MPEG2/DVD video because it burns to mini DVDs. AviDemux is great for editing MPEG2 stuff BUT you need to cut on Key Frames in order to NOT re-encode your video.
FIRST thing you do is place those VIDEO_TS folders on your external HDD.....then you start messing with/editing from there.
There are plenty of cheap or free lossless(or near lossless) editors out there for MPEG2/DVD. My favorite cheap one is
MPEGVCR.....my favorite free one is Avidemux but YOU must look after Key Frames and you must know the settings to output
without re-encoding. -
Depending on the kind of editing you're doing, you might not have to 'convert' (or reencode) them at all. Any reencode causes quality loss. Maybe what you want is a smart renderer that reencodes only where necessary and leaves the rest alone. The commercial VideoReDo TVSuite is one such product. MPEG Video Wizard DVD 5.0 is another. Both have free trials. If all you're doing is cutting stuff out there are plenty of good and free products. So, maybe give us an idea of what you want to do specifically.
Thanks Manono and Hech54 for your quick replies.
I want to brighten/darken some parts, cutting some parts out or put them later/earlier in the movie. It's just to make a nice movie for ourself and friends. And as I said before, save it to my ext. HD and burn some DVD's.So, maybe give us an idea of what you want to do specifically. -
Tomorrow I'll have a look at MPG Video Wizard. I didn't know that brightening requires reencoding. Thanks for that info.
Yes it does.
Also, unless you cut only only on key frames or use frame-specific smart rendering editor for MPEG, it'll be re-encoded. Always.
Seems you're not reading the previous replies. Or maybe you already know the basic difference between editable formats and final delivery formats. MPEG, BluRay, AVCHD, etc., are final delivery formats. Not designed for any editing or mods beyond simple I-frame cuts. http://telestreamblog.telestream.net/2012/04/save-yourself-frustration-use-editing-for...hen-editing-2/Last edited by LMotlow; 13th Jun 2015 at 09:06.
- My sister Ann's brother -
I strongly advice to do proper editing of the raw footage from camcorders.
You cannot simply take raw camcorder footage and expect people to sit through it unedited.
Editing is an integral part of the art of videography!
Thank you all for your replies. I'm still studying the subject, but I find the video techno far more complicated than photography. I'm afraid I have to wait till retirement to do it properly.
.VRO files ... joining and maybe converting
By Tafflad in forum Video ConversionReplies: 14Last Post: 16th Mar 2015, 07:31 -
Ripping and converting VOB files - best way and format?
By Theresa in forum Video ConversionReplies: 12Last Post: 16th Aug 2014, 21:40 -
Converting .VOB files
By Plandon in forum Video ConversionReplies: 5Last Post: 8th Jan 2013, 22:48 -
Problems Creating New Projects From .VRO/.VOB Source Disc
By RocknRollElitist in forum Video ConversionReplies: 0Last Post: 29th Oct 2010, 14:29 -
Converting vob files to one playable file
By Boen in forum DVD RippingReplies: 2Last Post: 31st Aug 2010, 22:27
