Hi All
I have been using DVDStyler for a while now. It was working fine last week but when I tried to use it this week it stopped working at the point it would normally start to Transcode/Remultiplex.
I have tried uninstalling the 32bit version and installing the latest 64 bit but I still have the same problem.
Below is what comes up in the details section.
Generating menus
Generating menu 1 of 2
Create menu MPEG
Multiplexing audio and video
Transcode video file: C:\Temp\dvd-tmp\menu0-0.mpg_bg.m2v
Need encode: false, use mplex: true
Multiplexing video and audio streams
Executing command: mplex -f 8 -S 0 -M -V -o "C:\Temp\dvd-tmp\menu0-0.mpg_bg.mpg" "C:\Temp\dvd-tmp\menu0-0.mpg_bg.m2v" "C:\Temp\dvd-tmp\menu0-0.mpg_bg.ac3"
Execution of command 'C:\Program Files\DVDStyler\bin\mplex -f 8 -S 0 -M -V -o "C:\Temp\dvd-tmp\menu0-0.mpg_bg.mpg" "C:\Temp\dvd-tmp\menu0-0.mpg_bg.m2v" "C:\Temp\dvd-tmp\menu0-0.mpg_bg.ac3"' failed (error 0: the operation completed successfully.)
Failed
Any help would be gratefully appreciated.
Results 1 to 1 of 1
DVDstyler hangs
By mobitech in forum Authoring (DVD)Replies: 2Last Post: 16th Feb 2015, 08:59 -
Novice needs help - DVDStyler
By alray1989 in forum Authoring (DVD)Replies: 2Last Post: 28th Sep 2013, 01:33 -
DVDSTYLER Help.
By wecosc12 in forum DVD RippingReplies: 4Last Post: 11th Aug 2012, 20:44 -
Encore 'can't transcode' file set to 'Don't Transcode', won't build ISO.
By koberulz in forum Authoring (DVD)Replies: 0Last Post: 5th Aug 2012, 12:18 -
Problem with DVDStyler?
By Regor21 in forum Authoring (DVD)Replies: 1Last Post: 22nd Oct 2010, 09:57
