Hi!
I want to rotate video. But not by 90, 180 or 270 degrees. I want to rotate the video e.g. by 52 degrees.
The older versions of Avidemux were not capable to rotate a video by an arbitrary angle. I have learned that Avidemux 2.6 can do this by using some OpenGL-Filters. But I dont know how to use this filter and where to get it.
What i have done so far:
1) I loaded some video into the editor
2) I choosed Mpeg4 AVC (x264) as video output
3) I clicked video->filter in Avidemux' menubar
4) I clicked on the OpenGL-Button... But: there are no OpenGL-Filters!
Now I'm stuck.
Does anyone know how to rotate a video by an arbitrary angle?
If you can't find the specific avidemux version that supposedly has this filter, basically all video editors can rotate at any angle eg. sony vegas, adobe premiere , etc.... A free one would be aviutl . Avisynth can do it too but it's script based , not user friendly to start with
You can use ffdshow plugin, you may use http://avisynth.org.ru/rotate/rotate.html
In both cases i would suggest explicitly oversample (upscale video even trough point resampling algorithm) at least 4 times to increase precision of the transformation.
rotating a video?
By VideoNoob123 in forum Newbie / General discussionsReplies: 12Last Post: 23rd Apr 2015, 12:21 -
Avidemux 2.6 Problem converting and rotating quicktime and mp4 to x264_mp4
By moses6533 in forum Video ConversionReplies: 12Last Post: 10th Dec 2012, 13:37 -
rotating video
By rosmari in forum EditingReplies: 17Last Post: 7th Nov 2011, 16:49 -
Rotating Video
By Debful in forum Newbie / General discussionsReplies: 5Last Post: 22nd Apr 2011, 09:22 -
Rotating a video
By vain in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2011, 10:52
