Results 1 to 13 of 13
    Feb 2015
    Brazil
    Some weeks ago I asked for some help to remove a logo from a video, and some nice fellows provided great solutions. Until then, I had never used Avisynth. Now I'm using it quite often and I'm very excited to learn new things.
    So, I have choosen a video to test myself and pratice. But I have some questions.
    I have two sources for the same video. The first one (source1.mpg) is the best one, but it has a logo. The second one (source2.mpg) does not have a logo, but it is from a VHS source.
    What I'm trying to do is to keep most of the screen area from source1, and use the logo area from source2. I'm using a script in Avisynth (running in hcenc) suggested by jagabo some weeks ago, with some modifications.
    I know it's impossible to match the two sources exactly, but I want to get as close as possible. The two sources aren't perfectly aligned and there are some level and color differences. I don't know exactly what's the code to align the sources. Also it's very difficult to find the correct parameters to match levels and colors.
    Find below the samples of the videos (source1.mpg, source2.mpg), the .d2v files (ziped), the script file (ziped), the mask file (ziped) and the resulting video (test.m2v). How can I improve this?
  2. Try using the ColourLike() filter.
    Feb 2015
    Brazil
    Thank you very much jagabo! Using the ColourLike, I managed to get a smoother result. It's not perfect, but I expected that, since source 2 has a lower quality. I don't think I can get a better result, thanks! The resulting video is attached.
  4. Did you crop away the edges of the frame and the logo for the first pass of ColourLike()?
    Feb 2015
    Brazil
    Yes I did. Otherwise the edges and the logo could mess the histogram.
    Do you think it's possible to get a better result?
  6. Originally Posted by virguloso View Post
    You could feather your mask (have the logo replacement part blend better into the source video so it's not so obviously a sharp rectangle). I don't know whether or not a mask in the shape of the logo , as opposed to your rectangle, would look any better to you or not, but I might be inclined to try it.
  7. I agree a more form fitting and more feathered mask would be less obvious.
    The registration of the two videos isn't great either. It doesn't matter much in this sample clip since there's not much detail in that corner. But it may be more obvious with other shots. Using v1.AddBorders(16,0,0,0) rather than v2.Resize() gives better alignment. You'll need new mask to match the new frame size.
    If you have a month to spare you could go through the videos and adjust the brightness/colors shot-by-shot.
    Feb 2015
    Brazil
    manono and jagabo, thanks for the suggestions. Actually making the adjustments shot-by-shot is out of question, but I managed to use the ColourLike twice, for the brighter and for the darker bits, and the result is better than before.
  9. That is a distinct improvement. If the rest of it is like your teste2.mpg, then good work!
    Feb 2015
    Brazil
    I've just uploaded the entire video on YouTube for your appreciation. Here's the link: https://youtu.be/Y6J_9VjUKWM
    I'm quite happy with the result!
  11. Originally Posted by virguloso View Post
    Hehe, not everyone appreciated it:
    This video contains content from Pink Floyd, who has blocked it on copyright grounds.
    Sorry about that.
    Feb 2015
    Brazil
    Oh what a shame. Find the video attached. It's 300mb.
  13. Nice work. I don't think anyone, unless they were told there had been a logo and where to look for it, would ever have guessed. It's obvious only in a couple of places.
    For future reference, you should have IVTC'd it and returned it to progressive 23.976fps. On YouTube the interlacing would have been noticeable also. It looks like a simple IVTC procedure using one of AviSynth's IVTC filters.
    Oh, I also think the volume is too low.
