Page 2 of 2
FirstFirst 1 2
Results 31 to 34 of 34
  1. Member vhelp's Avatar
    Mar 2001
    New York
    update - and success..
    i gave the 64GB SanDisk Ultra usb 3 flash drive, (fat32, 100MB/s speed) a test run anyway, and as it turns out, it is performing very well vs the 64GB and 32GB microSD that i tried. and under delphi xe7 there are no delays, compiling is quick, so far. Now i just need to find one that fits snugly without protruding out and quick to remove, and we are good to go.
  2. Member vhelp's Avatar
    Mar 2001
    New York
    Every so often my laptop mysteriously damages my usb 3 mem stick. I don't how it can do that since it is always in. When working on my programming projects, I leave the laptop on, but in sleep mode. Sometimes it goes into sleep mode if I leave it unattended for longer than an hour. Other times, I will just select the START button and select Sleep. I do this because I have a browser window open with so many tabs, (reloading them is slow and a pain), so I mainly have the laptop in sleep mode.
    However, last night I was ok with shutting it down completely, and went to bed. This morning I went to work and started up my laptop. And when I launched my Delphi XE7 app, it would not load, because it said that the mem stick was damaged and needed for format it. I put the mem stick in another computer and I got the same message, that is was damaged and needed to be reformatted.
    So, I ended up reformatting it. Then, I started to re-copy all the files from a folder on my laptop's HDD to the usb 3 mem stick. It took over 2 hours to copy 15GB of files, even over usb 3.0
    I am finding that I have do this more times than expected. I have decided that an SD card is not a good idea (unless I connect an external usb 3 host) so I am using a shallow usb 3.0 mem stick instead.
    What can I do to speed this whole copy process ?
  3. Are you absolutely certain that you have a legitimate memory stick? Lots of fakes being sold on Ebay.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  4. Mod Neophyte redwudz's Avatar
    USA
    I use these SanDisk Ultra fit models. The short ones stick out less than a 1/4", so not much worry about knocking them out of the socket. I have a 32GB and a 64GB.
    http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Descr...=-1&isNodeId=1
