The peaks matter, but bitrate viewer doesn't take into account the current state of buffer level, or the rate of data into the buffer. It only looks at data requested (ie. the water dripping out) , 1 of 3 components. You need to calculate input/ current level/output like a spreadsheet. Unlike a computer player, which essentially has an almost "infinite" buffer, devices with fixed function decoders do not. So it's not only the transfer rate that is important. Just because you have a USB HDD connection doesn't make you "safe" , unless it's connected to a HTPC . But I suspect you should be ok, since your average bitrates are so low
For the player issues - it's complex to debug because there are so many potential issues in the playback chain, from decoder, renderer, GPU settings, drivers etc... You should start another thread for that
Newer versions of VLC do have the correct colors now, at least on some setups
Results 61 to 61 of 61
mkvmerge append playback error when joining 2 mkv files from diff sources
By Owdrai in forum EditingReplies: 1Last Post: 26th Mar 2015, 10:53 -
I want to re-encode a AVI, MP4 or MKV
By Balema in forum Newbie / General discussionsReplies: 4Last Post: 22nd Feb 2014, 01:37 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Pixelation on mkv, mp4 and avi files
By ajkrishock in forum Newbie / General discussionsReplies: 10Last Post: 24th Nov 2010, 06:12 -
MP4 X.264 to AVI XviD - Hard Sub with ssa subtitles (1 step or 2 step?)
By ssray23 in forum SubtitleReplies: 4Last Post: 29th Aug 2010, 19:35
