Hi folks
I shot two videos for work purposes yesterday (.mov), file sizes 4GB and 559MB respectively, which I wish to compress and upload to my Dropbox account.
Having searched for ways to do this I came across Handbrake which I tested on the smaller file. It resulted in a larger 613MB .mp4 file.
Did I do something wrong?
Thanks in advance.
Prophet
Do you realize that every time you compress or convert a video it degrades the quality (unless the compression is lossless)?
Yes I do.That's why I'll retain the original .mov.
I wish, however, to share the video via Dropbox hence the wish to have a smaller file size version to upload. -
I would try VidCoder instead of Handbrake. It's a front end for Handbrake and makes adjustments easier. But with any conversion you need to pick either a quality or a size.
With your requirements, I suspect a size would be best. Try setting that in VidCoder/Handbrake and see if you like the results.
If not, then you need a larger size or some fine tuning of the encoder settings.
Another program that I use for .MOVs from my video camera is AVIDemux. It's an editor and a encoder. But I have more luck with the 64bit version of the program, no idea why. -
"Dropbox account" - do you have a size limit (mine's like ~236GB)? If not really, why re-compress? If so, is that the only way to share? If so, what is your actual available capacity? (assuming you don't intend to put more items up there for a while)
"Share the video" - Are you expecting users to view the file on-site? Dropbox isn't a streaming site, so users will have to download the file first (at best they could do 'progressive download' streaming). Why not use Youtube? Vimeo?...
Without getting these constraints ironed out ahead of time, you are stabbing blindly in the dark. How can you know if you've met your target if you don't even know what the target is? That's what you're doing wrong.
How do i convert a large (33GB) video file (.mov) to mpg?
By cocobeware in forum Video ConversionReplies: 8Last Post: 24th Dec 2014, 09:57 -
I want to compress mp3 file as much as possible. What should i use?
By gil900 in forum AudioReplies: 15Last Post: 8th Jan 2014, 18:06 -
How do I compress large avi files without losing any quality?
By Fieryterminator in forum Newbie / General discussionsReplies: 12Last Post: 7th Jul 2013, 06:59 -
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 18:21 -
Need To Compress Large AVI For Youtube
By r04dw4rri0r in forum Newbie / General discussionsReplies: 6Last Post: 30th Dec 2010, 11:18
