if i have a hour of avi video could i make fit it all on to one cd and make it a svcd?
thanks chad
Basically "YES" - thr problem however is that you are then lowering the bitrate so low, that the video feed will become very "boxy" - i.e. many artifacts.
You didn't specify if you're planning on using a 74min, 80min or even +90min CD-R, but as I mentioned above it won't be a pretty site, especially if you have lots of movement in the clip.
You might want to reconsider and use the VCD standards (or even push the VCD up a bit making it a XVCD) to get a better result. At lower bitrates mpeg1 has always been mentioned to give better results than mpeg2. -
VCD is not a good idea because that would only take 500MB or so of the CD. But first, of course, check the resolution and bitrate of the original. If it's near or under 352x240 it's a waste of time converting to SVCD.
Only very high quality sources should be made into SVCD or else you are just wasting time.
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 14:38 -
Burn 2 CDs at once
By orfajackson in forum Newbie / General discussionsReplies: 2Last Post: 27th Apr 2009, 22:03 -
Those 99-minute CDs.
By AlecWest in forum ComputerReplies: 14Last Post: 14th Dec 2007, 18:50 -
can write CDs okay but not DVDs
By johnsees in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 22:13
