I'm trying to capture my old 8mm analog tapes and convert them to H.265 MP4 files. I tried using VirtualDub to capture a raw AVI and then I used Handbrake to compress the raw video to H.265 MP4s. That works REALLY well for video but I can't get VirtualDub to capture the audio regardless of whether I connect the 8mm camcorder's audio outputs to the HVR-1600 or to my sound card. (If I use WinTV I can see the video and hear the audio.)
I also have an HVR-950 available if that helps.
	I don't have a Hauppauge HVR-1600, but if it works with VirtualDub, I guess it is possible to bypass the card's normal hardware encoding. You could try DScaler and AmaRecTV and see if those work any better. The HVR-950 doesn't hardware encode, so I would expect it to work with either DScaler or AmaRecTV.
  strange problem with hvr 2250 and hvr 1600 recording qubo channel.By godai in forum Capturing and VCRReplies: 1Last Post: 28th Dec 2012, 11:04
  Hauppauge WinTV HVR-1250 analog capture bug/glitchBy L-Train in forum Capturing and VCRReplies: 16Last Post: 20th Aug 2011, 18:42
  Capturing with Hauppauge HVR-1600 using s-video: granular pictureBy Skysis in forum Capturing and VCRReplies: 7Last Post: 25th Apr 2011, 20:54
  Using S-Video To Capture Into Hauppauge 1600 TV Tuner CardBy waldodiodio in forum Capturing and VCRReplies: 4Last Post: 1st Nov 2010, 18:49
  Analog Video Capture Hauppauge 1600By jrtmouse in forum Capturing and VCRReplies: 6Last Post: 13th Aug 2010, 15:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
