Hello,
I encountered a slight problem while editing footage recorded using Lagarith lossless codec. The raw avi is fine, but when I try to use it with Premiere Pro or AE, it loses some highlights (if you can call them that). Output seems a bit washed out and lighter. However when I preview the file in Premiere, it looks just fine, until Premiere renders the final frame. Hard to explain but you can check the problem below. Yes, Habbo, I know.
Has anyone had similar issues? I tried to fiddle with color correction but couldn't fix it. Any help will be greatly appreciated!
https://forum.videohelp.com/images/imgfiles/EVhGDWa.gifv
Make sure no color space conversion are occuring -e.g. you should be recording in lagarith RGB and exporting in lagarith RGB (or other RGB format)
Make sure no deinterlacing is occurring - you sequence settings, file interpretation settings, export settings should all be set to progressive -
How to maintain subject color but rest is b/w in Adobe Premiere Elements 11
By AAC in forum EditingReplies: 1Last Post: 17th Jan 2015, 09:21 -
loading lagarith or ut to premiere problem
By krohm in forum EditingReplies: 4Last Post: 14th May 2013, 00:07 -
Ut Codec Adobe Premiere Pro Export Problem.
By jtl999 in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2013, 23:15 -
lagarith - premiere - lagarith (without colorspace conversion)
By codemaster in forum EditingReplies: 10Last Post: 1st May 2012, 13:26 -
VOB to AVI (Lagarith lossless) Audio Out of Sync
By Eva-Unit01 in forum Video ConversionReplies: 10Last Post: 17th Aug 2010, 10:50
