Hi,
when I load an mts file from my PVR and cut it and then look at the output formats, I choose Mpeg-PS Muxer, there is a button "Configure".
When I click that there is:
Muxing Format: SVCD, VCD, DVD, Free
and "Allow non compliant stream"
1. What is "free" for?
2. "Allow non compliant stream", is that when e.g. I want to only play the stream on my Computer, but it does not have to be within the specifications for a DVD/SVCD/CD and so I would not later burn it on a DVD etc.? If my source (the mts file) has 4000kbps video and 256kbps audio and I choose free, will it be usable for a DVD later, anyway, because the bitrate was already under 9.5Mbit/s (v+a combined)?
I mainly convert ts to ps, because I want to keep bitrate etc. untouched and only want to make it more compatible (VLC under Mac OS X 10.4 PPC plays mts from my PVR choppy, while OS 10.9 and VLC does play it nice). If I want to keep it all untouched (no picture degradation) I choose "copy" for v output and a output. This is right thinking?
Since no one has answered yet, I'll guess 'Free' is simply a non-compliant choice, since the other choices are format complaint for: 'DVD, VCD, SVCD'.
If you select 'Free', then the ghosted selections below become available, IE, 'Total Muxrate, Video Muxrate and VBV size'.
I'm also guessing that 'Allow non-compliant stream' refers to the input stream as it doesn't seem to affect the lower selections.
Normally, the output for Mpeg-PS Muxer would be a DVD or one of the other compliant selections that you plan to burn to disc for set top playback.
But others likely will have a better explanation for this all.
TS Muxer strange error message..."AV frame too large"
By Iron Maiden UK in forum Blu-ray RippingReplies: 6Last Post: 6th Jan 2014, 07:00 -
Easy Free Video Editing Software for "QuickTime" format
By jsailorca in forum EditingReplies: 3Last Post: 6th Dec 2012, 20:32 -
How to edit "info.dvr" + How to match a particular MPEG format with FFMPEG
By falco2000 in forum Video ConversionReplies: 8Last Post: 27th Sep 2012, 12:00 -
Where does Avidemus store output videos?
By vampypiano in forum Video ConversionReplies: 3Last Post: 11th Feb 2012, 18:19 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52
