I'm trying to remove all the duplicates of this animated series which is difficult because a large amount of duplicates score higher than many legitimate non-duplicates such as slow panning or mist/clouds. The reason is probably because this cartoon is full of warping which I cannot fix.
But I noticed that this doesn't have to be so difficult because a cartoon essentially has 3 kinds of framerates, full, half and 1/3. The dup scores on these are rather predictable on a graph. When there's a duplicate every second frame, the graph shows spikes. Legit frames are many times the value of the duplicate so they can be filtered based on that. This way legit frames with small values won't disappear. But I don't know how to do this for scenes where every third is a legit frame:
36.6219 at -32,288 10.38388908
3.5268 at (0,320) 0.541460045
6.5135 at -224,384 0.188867174
34.4872 at -160,320 7.103439753
The fourth column is a formula in excel dividing a value by its previous. The threshold I set is to delete any frame with a score lower than 0.5, that is any frame that's succeeded by one with twice the value. Frames 2 and 3 should be deleted but only the third one will be using this.
Can anyone think of an Excel formula that'll take 3 frames into account instead of 2?
This is only a test run btw and I'm not sure what will result, I might have to change the threshold.
Results 1 to 30 of 43
Do you know about Dup() and DeDup()? Keep in mind that exact duplicate frames cost almost nothing in any inter frame encoding.
If those are typical numbers, that's a pretty big margin, you should be able to adjust the settings within dedup (there should be no reason to use excel) . Or is this question more about excel ?
jagabo, I have only used DeDup. And that duplicates cost almost nothing is completely false. Removing 50% of frames (all of them exact duplicates) decreased bitrate by 25% in 10 different animated videos I tested.
Originally Posted by poisondeathray
Setting the threshold that high will remove all these duplicates and then kill all the non-duplicates in other scenes with values far below that. So this is useless. What I need is a way to kill any small value consistenly surrounded by a big value which is easily done by dividing the first number by the second. This solves this scene's problem and would leave alone slow panning scenes with small values that aren't surrounded by big values.
frm 1441 diff from frm 1442 = 35.9146 at "-256,288" 6.475182548
frm 1442 diff from frm 1443 = 5.5465 at "(608,0)" 0.179759003
frm 1443 diff from frm 1444 = 30.8552 at "-320,256" 10.61629507
frm 1444 diff from frm 1445 = 2.9064 at "-256,160" 0.111036401
frm 1445 diff from frm 1446 = 26.1752 at "(384,96)" 4.630484008
frm 1446 diff from frm 1447 = 5.6528 at "(320,96)" 0.216141811
frm 1447 diff from frm 1448 = 26.1532 at "(384,96)" 5.487452791
frm 1448 diff from frm 1449 = 4.766 at "-512,320" 0.209058011
frm 1449 diff from frm 1450 = 22.7975 at "-320,256" 7.026073289
frm 1450 diff from frm 1451 = 3.2447 at "-64,288" 0.190551976
frm 1451 diff from frm 1452 = 17.0279 at "(384,96)" 5.253254766
frm 1452 diff from frm 1453 = 3.2414 at "-256,288" 0.200646248
frm 1453 diff from frm 1454 = 16.1548 at "(384,96)" 5.420346262
frm 1454 diff from frm 1455 = 2.9804 at "-320,256" 0.228211764
frm 1455 diff from frm 1456 = 13.0598 at "-320,256" 11.73492677
frm 1456 diff from frm 1457 = 1.1129 at "-320,192" 0.159372762
frm 1457 diff from frm 1458 = 6.983 at "-256,160" 3.499373591
frm 1458 diff from frm 1459 = 1.9955 at "(384,96)" 0.024428432
frm 1459 diff from frm 1460 = 81.6876 at "-224,160" 29.42318914
frm 1460 diff from frm 1461 = 2.7763 at "-320,256" 0.121364592
frm 1461 diff from frm 1462 = 22.8757 at "-320,320" 18.77519698
frm 1462 diff from frm 1463 = 1.2184 at "-160,192" 0.029882227
frm 1463 diff from frm 1464 = 40.7734 at "-320,288" 7.880288359
frm 1464 diff from frm 1465 = 5.1741 at "(0,352)" 0.136040238
frm 1465 diff from frm 1466 = 38.0336 at "-352,224" 20.69743143
frm 1466 diff from frm 1467 = 1.8376 at "(0,288)" 0.045935177
frm 1467 diff from frm 1468 = 40.0042 at "-320,160" 17.44927157
frm 1468 diff from frm 1469 = 2.2926 at "(0,352)" 0.039427047
frm 1469 diff from frm 1470 = 58.1479 at "-320,128" 45.35717629
frm 1470 diff from frm 1471 = 1.282 at "(192,32)" 0.021224533
frm 1471 diff from frm 1472 = 60.4018 at "-352,160" 20.98960976
frm 1472 diff from frm 1473 = 2.8777 at "(0,384)" 0.057400397
frm 1473 diff from frm 1474 = 50.1338 at "(384,96)" 11.24858085
frm 1474 diff from frm 1475 = 4.4569 at "(192,32)" 0.096459049
frm 1475 diff from frm 1476 = 46.2051 at "-320,128" 22.12675989
frm 1476 diff from frm 1477 = 2.0882 at "(352,64)" 0.052623223
frm 1477 diff from frm 1478 = 39.6821 at "-320,128" 20.97362579
But it's the parts with 2-duplicates-1-legit pattern that I'm trying to figure a way to fix, because this method won't work with those. -
Did you try the other usual approaches, manipulating the data before dedup?
e.g. use dedup on a denoised or temporal stabilized version, and apply the results to the original . For example if noise or warping makes 2 duplicates "look different", denosing or heavy temporal stabilizing should increase the accuracy -
That's what I usually do but it won't work here. Temporal denoising/smoothing won't fix the warping and in addition to that will just screw up legitimate frames in slow pans or cloud movements.
You are completely wrong, I did remove exact duplicates. I know that because I used ExactDeDup instead of DeDup. It was a RGB32 video which DeDup can't process. -
Not sure how to do it in excel or if it will even be accurate enough. What about less that 0.6 for excel ? how are the other scenes ?
Can you describe the warping, pattern, frequency, areas of frame affected ?
dedup only checks 1 condition , but you might be able to set multiple conditions with writefileif() and using runtime functions . You have to satisfy several logical conditions for it to write the frame number -
Yeah looks like I'll have to play around with excel a bit more or ask Microsoft.
Threshold of 0.5 would kill only the third duplicate but leave the second one intact. Raising it to 1.2 would kill numerous legit frames.
Whatever, I'll figure something out. -
Yes writefileif() will be more complicated than adjusting a dedup log. But setting multiple conditions will definitely make it much more accurate. Also, it will only give you the frame numbers, it won't give you the VFR codes
So I tried =A1/(A2+A3) formula which works on the 1/3 FPS parts and surprisingly on the other parts as well. This got rid of 30% of the frames and lowered file size by 20%, jagabo.
Unfortunately, this formula isn't effective enough. It always deletes 2 frames before a scene change which are often not duplicates and I overlooked one serious problem: there are scenes where the background runs at full FPS while the large object is at half FPS. This too produces "spikes" and the frames where only the mostly-covered background moves are deleted.
This I will need to rethink how much bigger a spike must be to qualify as one after Microsoft customer service gives me a tip how to better detect spikes.
The good news is this method doesn't really affect scenes with little or no movement. Only like one legitimate frame is randomly removed per scene. -
Animations is not my thing so I suppose I can be educated on this.
Why would anyone want to remove duplicates, aren't they there to give the animation the pace the director wanted?
With motion-compensated prediction in inter-frame compression, you really gain no bitrate benefit of VFR over CFR (for the same quality), and you incur motion aliasing artifacts (because of changing timebase) and player incompatibilities. All downsides and no upsides. Why put yourself (and others) through that?
Scott -
But there is a limit of how many frames can be referenced which is 16. Content such as animation and 2D video games benefit linearly from more refs. When you double the frame rate, 16 refs effectively become 8. Removing duplicates is incredibly beneficial.
Scott -
Who are "you folks"? And more I-frames decrease the quality, actually.
El Heggunte, who's talking about the I-frame interval? That has no noticeable effect quality or compression unless it's extremely low. A keyint larger than default has little benefit and whoever told you otherwise is a clueless moron.
The frame buffer the refs control which is the range of arbitrary frame reodering on the other hand affects some content greatly.
Doubling the frames will limit the amount of frames that can be strategically re-ordered in the buffer. -
newpball is talking about very high bitrates, where having more I-frames would increase the quality
Have you tried using the Compare function to compare adjacent frames? It's text output provides like 5 or 6 different metric numbers for analysis.
@ El Habanero: thanks for NOT answering my question
P.S.: I'm leaving this thread, since the O.P. has finally confirmed he's a troll.Last edited by El Heggunte; 8th Jun 2015 at 05:22. Reason: add P.S.
Almost every recent TV or Blu-Ray player from one of the major consumer electronics brands is able to play MKV files, with some restrictions. (These devices impose some restrictions on every container file format they play.) What more is needed to qualify as mainstream support?
Okay, this is too weird. I tried a new excel formula on the dedup log to process it in both directions and it left me with exactly an FPS of 17.5 which from my experience is the average FPS you end up with when removing duplicates from a 24p cartoon. But I'm serious, it cut this 23.976 fps to exactly 17.500.
When you're math-retarded like me, you don't believe this can be just a coincidence.
But for the most part, it is. This method fixes the problem of legits being removed before a scenechange and less legits removed in general but it still happens occasionally.
I could live with this.
Khaver, does the compare function output timecodes? -
The MKV project started in 2002, although as far as I can tell, it is still unfinished. In 2015 the menu feature still hasn't been implemented, and there is no universally accepted standard governing metadata.
I wouldn't say MKV was incredibly popular in 2006. Going by the posts I remember seeing at VideoHelp in those days, SD XVid or DivX video in an AVI container was far more popular than MKV.
In 2006, many things were different. Most people did not have an LCD TV or a Blu-Ray player, and if they did, those devices did not play media files. There was limited support for SD XVid or DivX video in an AVI container among DVD players.
I'm really more concerned about what is true about MKV support for today's consumer electronics. I would say that today, MKV support there is mainstream, but if you want to encode your video so that it won't play properly except with a PC, that's your prerogative. -
I meant for H264. Most did not use AVI or MP4 for AVC video. Hell some put Xvid into MKV as well because AVI didn't support Xvid without hacks either.
But you answered your own question. Xvid in AVI was insanely popular and nothing except a PC would play them.
That should tell you that people could care less for hardware compliance. Nobody watches TV anymore and people use Blu-ray players to watch actual Blu-ray movies, not highly-compressed substandard crap from the internet.
Need advice on managing home videos (family stuff)
By zaerdy in forum Newbie / General discussionsReplies: 21Last Post: 20th May 2015, 11:51 -
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 17:53 -
Can't see data on a DVD-RW ! Please help!
By Icaro in forum MediaReplies: 10Last Post: 20th Jan 2011, 04:45 -
Advise needed on managing digital video collection...
By nharikrishna in forum CapturingReplies: 2Last Post: 18th Jan 2011, 06:20 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00
