When trying to "Save WAV" in a DivX AVI, get an error message that says the requested compression format is not compatible with the input file.
The source file's audio codec is: Unknown (tag 2000) and it has 5 channel stereo.
I selected full processing mode, then PCM (no compression)... wouldn't work.
Any clues????
I obviously has something to do with the source AVI, because I just successfully extracted the audio from a different AVI file which listed the audio as MPEG Layer-3 with 2 channel stereo.
Not sure why VirtualDub has this problem, but... I was able to convert the AVI to one with uncompressed audio using AVI Audio Decompressor Ver 1.4. Then I could extract the audio with VirtualDub.
how to extract audio from avi
By ShrinkDWorld in forum AudioReplies: 2Last Post: 2nd Feb 2012, 17:58 -
cannot see or extract audio from AVI
By Srivas in forum Video ConversionReplies: 6Last Post: 7th Dec 2011, 23:47 -
By Srivas in forum Video ConversionReplies: 1Last Post: 7th Dec 2011, 01:49 -
extract avi audio problem
By gibkho in forum AudioReplies: 8Last Post: 13th Jun 2010, 13:18 -
How to extract audio from avi
By JConnor in forum Newbie / General discussionsReplies: 13Last Post: 21st Sep 2007, 12:12
