Results 1 to 9 of 9
Ok, so with sound the video is 4m 48s, but, it is out of sync, but with only video it is 4m 34s. The Mediainfo info is here (sound) and here (video).
Given it's an AVI, open it with VirtualDub and check the total number of frames (or check another way if you prefer).
I don't use Handbrake much but it's log file is pretty detailed. It should tell you how many frames it expected, how many it got, how many it duplicated/dropped if need be and the total output. See if it matches up.
Is it possible the video stream in the original AVI is slightly shorter than the audio stream? Do you appear to be missing video anywhere? Is the audio still in sync?
Edit: Sorry I missed yuour last post where you said the audio is out of sync. Try opening the Handbrake output with My MP4BoxGUI or MKVMergeGUI (if you don't mind MKV as it's easier to use) apply an appropriate delay to the audio or video stream and save that as a new MP4/MKV (I'd test with MKVMergeGUI first as it's easy to use) to see if it fixes the audio sync.
Or try an older version of Handbrake (ie version 0.9.9). Maybe it's a bug. There's been a few "what is handbrake doing?" type posts recently.
Just some ideas....Last edited by hello_hello; 3rd Jun 2015 at 10:03.
VirtualDubMod (simple?) question about speeding up a portion of a video
By kaosguy in forum Video ConversionReplies: 3Last Post: 3rd Jan 2014, 16:20 -
Removing the first 18 seconds of a video
By Simmons in forum Video ConversionReplies: 9Last Post: 14th Jun 2011, 06:18 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 23:14 -
stills to video speeding up frames/sec or stop motion
By slnorth in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2010, 23:06 -
Trying to make a time-lapse video (speeding up original footage): How?
By maskingtape in forum EditingReplies: 30Last Post: 16th Jul 2010, 00:39
