For a movie clip made on 26th May 2015 at 09:16:12 (UTC), i.e. 2015-05-26 09:16:12, MediaInfo reports 2003-07-11 14:08:33.
Made with what? It might just set that date for all videos.
Maybe you never properly reset the clock/calendar in the cam?
Maybe some app/device/process that uploaded/converted it also reset the stamp? (what's the provenance...)
Samples/More info?
Scott -
Thanks both. It was made with the Polaroid CUBE and I reckon you're right about the cause - it's set some sort of default date. (A strange one, about 10 years before I bought it!) The device itself has no controls apart from one button but there may be a software setting I've missed.
A test I should have done before posting: I tried a video clip from my Canon Ixus 220 HS and MediaInfo reported its date correctly.
Terry, East Grinstead, UK -
User Guide page 14 > http://www.polaroidcube.com/skin/frontend/default/polaroidcube/images/polaroid-user-guide.pdf
Basically you connect via USB to the computer and launch the "Your Settings Application". In the app you can change the light frequency, timestamp, cycle recording, date & time, and buzzer volume.Google is your Friend
videos/pictures - how can modify date be before creation date
By jyeh74 in forum Off topicReplies: 2Last Post: 20th Oct 2013, 16:12 -
Gspot vs Mediainfo
By Creed92 in forum Newbie / General discussionsReplies: 25Last Post: 23rd Jun 2013, 14:12 -
videos or pictures - date created vs date modified
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 4th Oct 2012, 17:00 -
MediaInfo : what does this figure mean?
By Bonie81 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2011, 23:22 -
[MediaInfo] What exactly is bitrate ?
By Klagar in forum Video ConversionReplies: 2Last Post: 3rd Nov 2010, 10:54
