Actually, you do not need that.
Load the folder into imgburn and insert a blank disk and click on the calculator icon. If it is over-size then you will get an appropriate message.
Results 31 to 36 of 36
While you're at it, burn with ImgBurn as well instead of DVD Architect.
(Cc, post #21 edit noted. OK
any particular reason not to use DVD architect ........ I thought as its part of same 'suite; would interop better
When I started authoring dvds, I always used the burner of the program. I was getting errors/wasting disks.
Then I started reading here and discovered programs that do the same but only better. Oh. You could still waste disks if you use rubbish media. But quality disks (Verbatim) + imgburn are a marriage made in heaven.
Large files
By Jomapil in forum ComputerReplies: 18Last Post: 4th Mar 2014, 16:46 -
Encoding/Transcoding LARGE files...help!
By PsychOfMSE in forum ComputerReplies: 14Last Post: 19th Sep 2013, 20:34 -
Burning large files
By cp2burner in forum Authoring (Blu-ray)Replies: 1Last Post: 7th Jun 2012, 23:52 -
MPG files are too large
By sldvd in forum Video ConversionReplies: 2Last Post: 6th Mar 2011, 05:59 -
Copying Large Files
By persephone in forum ComputerReplies: 14Last Post: 13th Dec 2010, 03:23
