i am riping x - 1999 wich is an anime from dvd and i want it in jap with english subs how do i activate the subtitles to appear on the rip? and at what stage to i turn them on? (if you have a guide or a site with out it would help alot) thanks much
Static is in the minds and hearts of all mankind the sad part is... that we never fully comprehend the concept that is static.
Do you convert to VCD, SVCD, DVD or AVI? Which tools do you [want to] use?
ScriptClub.com
You might want to ask the kind folks in the forums at ScriptClub.com about specifics of finding and applying subtitles to various foreign films. I believe there are several different techniques and tools. I have only recently learned of this myself, so I don't have any specifics. [NOTE: Unfortunately, the site is temporarily unavailable at this time... ~*SIGH*~ - AR, TCS -
accualy one of the riping guids helped me alot just for future referance to any one .... DVDx does it all! it dosn't need to rip it cause it accesses the dvd don't need to convert it cause its in mpeg and it allowes you to use subtitles (and the file isn't all that big) so just talke a look at it its very esay ... but make sure you set the output file to the whole thing not just a segment :) but thanks for the help youguys... keep up the good work *aplauds*
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 09:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 16:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 17:10
