  1. Hi everyone,
    I'm currently trying to frameserve these files with Avisynth via DirectShowSource() to MPC-HC looking for a rendition of the video with "hardsubbed" subtitles which, however, produces a grey screen in the respective file's resolution and working audio with file #1 and audio on fast forward with file #2.
    [Saizen]_Kuroko's_Basketball_-_01_[1080p][Blu-Ray][F64381D7].mkv
    General
    Unique ID                      : 181734229447955904632565719224783255414 (0x88B8BD4C0804A54C89C4393A92B0B776)
    Format                         : Matroska
    Format version                 : Version 4 / Version 2
    File size                      : 1.36 GiB
    Duration                       : 24mn 9s
    Overall bit rate mode          : Variable
    Overall bit rate               : 8 068 Kbps
    Encoded date                   : UTC 2014-04-06 18:04:06
    Writing application            : mkvmerge v6.4.1 ('Omega Point') built on Sep 16 2013 22:05:10
    Writing library                : libebml v1.3.0 + libmatroska v1.4.1
    Attachements                   : 321impact.ttf / A-OTF-ShinGoPr5-Bold.otf / ArchitectsDaughter.ttf / arial.ttf / BebasNeue.otf / calibri.ttf / calibrib.ttf / calibriz.ttf / cambria.ttc / DCHLei5.ttc / DK Crayon Crumble.ttf / full Pack 2025 filling.ttf / indiestarbb_bld.ttf / indiestarbb_reg.ttf / IwaGyoPro-Bd-Kami.ttf / IwaOMinPro-Hv-Fate.ttf / Just Gotta Smile.ttf / KozGoPr6N-Bold-Mikakunin.ttf / KozGoProH-Madoka.ttf / Miss Monkey.ttf / pdf file write up.pdf / Something Blue.ttf / times.ttf / timesbd.ttf / YummyCupcakes.ttf
    Video
    Format                         : AVC
    Format/Info                    : Advanced Video Codec
    Format profile                 : High 10@L5.1
    Format settings, CABAC         : Yes
    Format settings, ReFrames      : 16 frames
    Codec ID                       : V_MPEG4/ISO/AVC
    Duration                       : 24mn 9s
    Width                          : 1 912 pixels
    Height                         : 1 080 pixels
    Display aspect ratio           : 16:9
    Frame rate mode                : Constant
    Frame rate                     : 23.976 fps
    Color space                    : YUV
    Chroma subsampling             : 4:2:0
    Bit depth                      : 10 bits
    Scan type                      : Progressive
    Writing library                : x264 core 142 r2409 d6b4e63
    Encoding settings              : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=15.0 / qcomp=0.80 / qpmin=0 / qpmax=32 / qpstep=4 / ip_ratio=1.40 / aq=2:1.00
    Language                       : English
    Default                        : Yes
    Forced                         : No
    Matrix coefficients            : BT.709
    Color range                    : Limited
    Audio
    Format                         : FLAC
    Format/Info                    : Free Lossless Audio Codec
    Codec ID                       : A_FLAC
    Duration                       : 24mn 9s
    Bit rate mode                  : Variable
    Channel(s)                     : 2 channels
    Sampling rate                  : 48.0 KHz
    Bit depth                      : 16 bits
    Writing library                : libFLAC 1.2.1 (UTC 2007-09-17)
    Language                       : Japanese
    Default                        : Yes
    Forced                         : No
    Text
    Format                         : ASS
    Codec ID                       : S_TEXT/ASS
    Codec ID/Info                  : Advanced Sub Station Alpha
    Compression mode               : Lossless
    Language                       : English
    Default                        : Yes
    Forced                         : No
    Menu
    00:00:00.000                   : :Prologue
    00:00:42.020                   : :Opening
    00:02:11.980                   : :Main
    00:22:24.020                   : :Ending
    00:23:54.030                   : :Preview
    [Asenshi] Kuroko no Basuke 2 - 01 [BEAAD944].mkv
    General
    Unique ID                      : 183811980559438134522991456039054763895 (0x8A48E655FE4D402EBCDB6154A1EE6777)
    Format                         : Matroska
    Format version                 : Version 2
    File size                      : 398 MiB
    Duration                       : 24mn 9s
    Overall bit rate               : 2 305 Kbps
    Encoded date                   : UTC 2013-10-06 03:00:58
    Writing application            : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct  9 2011 11:55:43
    Writing library                : libebml v1.2.2 + libmatroska v1.3.0
    Attachements                   : BeeMarkerInk.TTF / belligerent.ttf / cambriab.ttf / Lato-Bol.ttf / Lato-BolIta.ttf / Marker SD 1.2.ttf / Marker SD.ttf / Marker_SD_1.2.ttf / Aero Matics Display Bold.ttf / arialbd.ttf
    Video
    Format                         : AVC
    Format profile                 : High 10@L5.0
    Muxing mode                    : Header stripping
    Duration                       : 24mn 9s
    Width                          : 1 280 pixels
    Height                         : 720 pixels
    Color space                    : YUV
    Bit depth                      : 10 bits
    Writing library                : x264 core 135 r2345kMod f0c1c53
    Encoding settings              : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / fade_compensate=0.76 / psy_rd=0.65:0.05 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=16.8000 / qcomp=0.70 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.80
    Language                       : English
    Default                        : Yes
    Forced                         : No
    Audio
    Format                         : AAC
    Format/Info                    : Advanced Audio Codec
    Format profile                 : LC
    Codec ID                       : A_AAC
    Duration                       : 24mn 9s
    Channel positions              : Front: L R
    Compression mode               : Lossy
    Default                        : Yes
    Forced                         : No
    Text
    Format                         : ASS
    Default                        : Yes
    Forced                         : No
    Menu
    00:02:13.759                   : :OP
    00:03:44.015                   : :Part A
    00:09:45.919                   : :Part B
    00:22:21.757                   : :ED
    00:23:51.722                   : :Preview
    00:24:06.612                   : :See you next week!
    My video playback setup: (all up-to-date as far as I know)
    Avisynth 2.6.0 (x86)
    LAVFilters 0.65 x86 (LAVAudio, LAVVideo, LAVSplitter in use)
    xy-VSFilter 3.0.0.306 x86
    MPC-HC 1.7.8 x86 (no internal filters used)
    After testing various files, I've realised that the subtitles must be reason for this. I'm trying to make it work with LAVFilters and DirectShowSource(), so Haali Media Splitter and FFmpegSource2() is no option for me. When using Haali Media Splitter 23062013 with Automatic Loading of VSFilter, it works though. Does someone know how I have to tweak my setup to make it work?
    By the way, I also would like to know why Avisynth loads two splitters all the time.
    Thanks in advance!
  2. DECEASED
    Jun 2009
    Heaven
    For dealing with embedded subtitles, LAV Filters require the "normal" DirectVobSub, NOT the 'auto-loading' one.
    If you really need to use DirectShowSource() in this case, you'd better use a .GRF file
    (and configure the DS filters correctly as well).
    http://avisynth.org.ru/docs/english/corefilters/directshowsource.htm
