  1. Hi all,
    I'm new to this forum. I've been searching for 2 days a way to systematically delete non-english tracks from a hundred MKVs I have, all of them being in the same folder, using a single batch command.
    I haven't found it. I know I could do this file by file with MKVToolnix, but it would take me forever.
    I want to keep the English audio track along with the English subs, and the other tracks deleted.
    I'm using OS X 10.10.3, with a rMBP 13". I have the latest MKVToolnix installed, with MediaInfo.
    Here's an example of a MKV I'd like to be processed.
    General
    Format : Matroska
    Format version : Version 2
    File size : 3.86 GiB
    Duration : 43mn 4s
    Overall bit rate : 12.8 Mbps
    Movie name : LOST S05E01 Bluray 1080p Multi DTS HDMA x264-MAN OF STYLE.mkv
    Writing application : HandBrake 0.10.1 2015030800
    Writing library : Lavf55.12.0
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 43mn 4s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Writing library : x264 core 142 r2479 dd79a61
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Mode : 16
    Format settings, Endianness : Big
    Codec ID : A_DTS
    Duration : 43mn 4s
    Bit rate mode : Constant
    Bit rate : 1 509 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 465 MiB (12%)
    Title : Surround
    Language : French
    Default : Yes
    Forced : No
    Audio #2
    Format : DTS
    Format profile : MA / Core
    Mode : 16
    Codec ID : A_DTS
    Duration : 43mn 4s
    Bit rate mode : Variable
    Bit rate : Unknown / 1 509 Kbps
    Bit depth : 24 bits
    Compression mode : Lossless / Lossy
    Title : Surround
    Language : English
    Default : No
    Forced : No
    Text #1
    Format : PGS
    Codec ID : S_HDMV/PGS
    Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
    Language : English
    Default : No
    Forced : No
    Text #2
    Format : PGS
    Language : French
    Default : No
    Forced : No
    Text #3
    Format : PGS
    Language : French
    Default : No
    Forced : No
    Text #4
    Format : PGS
    Language : French
    Default : No
    Forced : No
    Menu
    00:00:00.000 : :(01)00:00:00:000
    00:05:34.000 : :(02)00:05:33:916
    00:12:14.734 : :(03)00:12:14:608
    00:19:38.886 : :(04)00:19:38:802
    00:27:01.119 : :(05)00:27:01:036
    00:34:47.293 : :(06)00:34:47:210
    00:42:26.794 : :(07)00:42:26:710
    Any chance I could perform this easily ? I'm not a power user.
    Thanks.
    Dual boot into windows and try mkvcleaver. .
    I haven't seen any other easy batch code for stripping out tracks just by language.
  3. Create a .bat file with:
    md output
    for %%a in (*.mkv) do mkvmerge -o "output\%%~na.mkv" --audio-tracks 2 --subtitle-tracks 3 "%%a"
    /edit:
    Oh, you're not on Windows. I'll let it here to show you the general mkvmerge command, though. Maybe you can adapt it for OS X.
    /edit2:
    No OS X to test here, but probably something like that:
    #!/bin/bash
    mkdir "output"
    for filename in ./*.mkv
    do
         mkvmerge -o "./output/$filename" --audio-tracks 2 --subtitle-tracks 3 "./$filename"
    done
    Does that strip by language? If the mkvs are muxed different. If all are same it would work though.
  5. It's not by language. If the files have varying track orders the script would have to be vastly more complicated because mkvmerge has no commands to filter input by language. You'd have to do some parsing of mkvmerge --identify-verbose. That said, as long as English is always the second audio as well as the first subtitle track it will work.
