Hello all,
I am trying to make a DVD (as i have done countless times before) with DVD flick and have downloaded a video in MP4 720P and when i try to add it to DVD flick it says it has no usable video track and will not be added.
Why is this?? I can watch it fine, so obviously there is a video track.
Why does DVD flick not think so?
				Results 1 to 11 of 11
	Fantastic!! Excellent answer.
 I will be installing it ASAP and will report back.
	Hi, I've met same problem too, u may try changing the mp4 location, maybe it works. (I changed the mp4 from the download folder to desktop)
	You just need to shorten the file name to max 3 words without any special character.
	All "no usable video track" errors I have seen is due to 'Visual Usability Information' in the codec. You can use VLC to view codec information. If you see 'Color primaries...', 'Color transfer function...', and/or 'Color space...', probably too new for DVD Flick. If you see these, and maybe other things, you can use XMedia Recode (Free) to recode the MP4 file. Ensure 'Visual Usability Information' is set to 'Unspecified'. Recode, and for me, DVD Flick did not have a problem with the recoded file - it works.
	Is that (recode) a fast operation, or does this convert the file? (which usually takes about 5 hours on my weak windows 7 netbook).use XMedia Recode (Free) to recode the MP4 file.
	I am using Win10 on a workstation. For reference, a 90 minute mp4 clip re-coded in 12 minutes. Like DVD Flick, Xmedia uses ffmpeg, and I think DVD Flick does more processing (to make fit) than Xmedia recode. Its worth a try, use a 15 minute or 30 minute clip as a test run.
  What program to use to burn my avchd video to a DVD usable in a DVD player?By SSE in forum Newbie / General discussionsReplies: 3Last Post: 26th Nov 2013, 19:08
  'MP4 has no usable track' yet plays in VLC Media PlayerBy JuliaR in forum Newbie / General discussionsReplies: 6Last Post: 10th Mar 2012, 18:57
  Audio track shorter than video track in MPEG Video Wizard DVD?By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 14:24
  Merge video files in DVD Flick?By morgle in forum EditingReplies: 6Last Post: 13th Aug 2010, 11:28
  Get audio track from DVD Extra instead of film sound track in VIDEO TSBy Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
