I got a dvd sub and want to edit the timing and sync it with blu-ray sources?
The problem is the bluray video may add a few minutes so there will be a different frame rate!! i tried syncing it with Subtitle Edit but it didn't solve the whole timing issue, it syncs at first but then losses after a while! is there a way to fix this???? *There is only one non-english sub to this movie in subscene.
Results 1 to 10 of 10
Did you try the point sync in Subtitle Edit?
http://www.nikse.dk/SubtitleEdit/Help#sync -
Yes I tried all the synchronization methods, but it doesn't work perfectly.
Doesn't it have any subs from where to get time codes?with blu-ray sources?
Sounds odd to me. If you tried to sync the whole subtitle the first and last should be in sync. You DO know that you can sync part of a subtitle in SE using either point- or visual- sync?but then losses after a while! -
Yes it has bluray subs which i could take time codes but it is a different language, so it does not match the original lines.
Yes i tried visual-sync, it gets better but not perfectly synced. And in point-sync i should sync every line. more than 1000 it takes alot of time. -
That's OK. Perform OCR on those in SE. Untick "Prompt for unknown word" (You just need time codes)so it does not match the original lines
No. You migth be able to sync the whole file at once. Otherwise you sync parts like perhaps 10-15 min at a time identifying identical subs and copy-paste the timecode from the BD source to the point-sync. I made the attached video for another post showing how.And in point-sync i should sync every line
Use the timing from a good srt in a bad srt that is not synched
By shernoam in forum SubtitleReplies: 4Last Post: 4th Nov 2014, 06:44 -
generate and automate the timing in srt files
By Aly Saleem in forum SubtitleReplies: 1Last Post: 28th Jan 2014, 02:08 -
Doki Timing Guide - Creating / Timing Subtitles
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 27th Jul 2013, 23:25 -
no subs on avi/srt with same name
By David Banner in forum Newbie / General discussionsReplies: 1Last Post: 24th Jun 2012, 19:36 -
SRT or Subs for MKV2VOB
By Boen in forum Blu-ray RippingReplies: 1Last Post: 1st Sep 2010, 04:44
