I just bought an elitebook 2560P at http://www.laptop-kopen.nl/hp-elitebook-2560p but it can only connect at 11Mbps it has to go to 300mbps my router is also 300 mbps?
				Results 1 to 10 of 10
	I moved your post to a new thread,doesn't belong in the previous thread,not the same issue. I think,therefore i am a hamster.
	Good explanation at http://compnetworking.about.com/od/wireless/f/80211n-300-mbps.htm
 Also, anything on the local network that limits its throughput may cause the upper limit to be the lowest device limit.
	Probable router sets to B only (max speed specs is 11MBs).
 Claudio
	I removed the drivers from windows and did an clean install. Now it sees 2 networks 2.4ghz and 5ghz. At 5ghz it connects now at high speed. Download are 7 mb/sec now.
 Thanx
	You mean 7 mbytes,7mb is 1/8 the speed. I think,therefore i am a hamster.
	If you can't be consistent with your unit prefixes nobody can know what you're talking about.
 https://en.wikipedia.org/wiki/International_System_of_Units#Prefixes
 In general, capitals refer to positive powers of 10, lower case for negative powers of 10: M=mega, m=milli. Use B for byte (8 bits), b for bit. Or just spell it out and and there will be no ambiguity: megabyte, megabit.
  Which laptop?By alegator in forum ComputerReplies: 0Last Post: 8th Oct 2012, 14:46
  choosing a new laptopBy vhelp in forum ComputerReplies: 28Last Post: 22nd Sep 2012, 20:12
  How to get Firewire on my laptopBy kelemvor in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 2nd Aug 2011, 23:14
  Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15
  Have you seen a video camera connects a DVD burner directly without PC?By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 8th Oct 2010, 06:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
