Hi! guys , nice work
I've tried some converter but I can't have both audio tracks that have the .mkv . So my question is what would be the best free or cheap software that can convert a .mkv (with 2 audio tracks) into an .iso or Video_TS ready to be burn. Some .mkv are double layers so it need to be able to fit on a DVD5. And it could be doing the inverse, take a video_ts or a .iso and make a .mkv (with 2 audio tracks). If you can have 2-3
choices that would be super. Thanks for your support. Dan
hi,
For mkv to regular dvd (resolution 720X480) , try AVStoDVD.
For mkv to AVCHD dvd (resolution 1280X720 - 1920X1080p), try BD-Rebuilder (re-encoding) or Tsmuxer (no re-encoding)
For iso to mkv, try Makemkv
Removing audio tracks from mkv
By MaRa-23 in forum Video ConversionReplies: 39Last Post: 20th Oct 2015, 05:25 -
Any way to see delay applied to audio tracks in an MKV ?
By cpaqf1 in forum Video ConversionReplies: 3Last Post: 22nd Apr 2014, 16:13 -
How to remove audio tracks from many MKV files?
By santaxl in forum Video ConversionReplies: 12Last Post: 21st Jan 2014, 05:04 -
Can't select audio tracks MKV LG BP33
By hecramsey in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Dec 2013, 18:31 -
MKV To VIDEO_TS / ISO / DVD
By Valentin in forum MacReplies: 1Last Post: 31st Aug 2010, 21:13
