So I went ahead to upgrade my old TMPGEnc 5 to the new 6, because 10bit color depth and HEVC seemed quite tempting to try. Unfortunately I now often get the error "The An error occurred in the DirectShow File Reader bridge system terminated abnormally (5)". After that, it opens the preview window with the correct frame count of the source I want to import, but the preview is entirely black and I can't close TMPGEnc normally, have to kill the process in the task manager.
Does anybody have a clue what that error means and how to fix it? I can rule out that my scripts are ****ed, since they work fine in VirtualDubMod. I just prefer TMPGEnc's interface and some of its functions, so I'd be quite happy to be able to continue to use that properly. I have not yet been able to determine what exactly causes the scripts to produce this error, it seems quite random. One that's repeatedly given me problems was:
That dga index is pointing to an .h264 file extracted from a BluRay. If I do these same operations with a DirectShowSource or AVISource (for example importing a .ts file that's been captured from TV or whatever), it seems to work more often, but even then I have to re-try it countless times for TMPGEnc to load the video correctly.Code:AVCSource("x:\xxx\xxxxx\00012.dga") ConvertToYV12() MCTemporalDenoise(settings="low")
Never had these problems in TMPGEnc 5 once. I noticed that TMPGEnc 6 has some restrictions for some file formats and certain codecs, according to their website, but I don't think that's been any different in 5.
I think that's all I have to say for now, feel free to ask for more info if you should need it. Help would be much appreciated.
Results 1 to 10 of 10
you can create a fake avi with avs2avi
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Unfortunately keeps crashing for me, never used it before though, so I might be doing something wrong. Wouldn't that be essentially the same as encoding with VirtualDubMod to avi?
Not even close, virtualmode makes real avi with a substantial amount of data in the end (+/- large file) , avs2avi does the opposite (= very small file) but such a file is only useable for softwares so you can import the fake avi and reencode it (sony vegas is an example)
The way it works is simple: Drag your avs script to the avs2avi executable directly*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Great, I've been doing that right then, but for some reason it just keeps crashing after a couple seconds of being open. And it's really just a matter of time, it doesn't matter which options I pick, even if I pick nothing, it crashes after 10 seconds or so. Any clue what that's about?
Thanks very much for your help so far
I think avs2avi could really be helpful here.
You can try avfs (avisynth virtual file system) , which is much more stable than avs2avi
Always a pleasure to see you poisondeathray! That Pismo File Mount Package does create some system instability at times... The first time I tried it my whole computer locked up until I killed the process. After a quick reboot I tried again and TMPGEnc actually read a script that never once worked before! Thanks so much, that means I can continue using it
Nonetheless many thanks to themaster, you definitely set me on the right path! -
Hi everybody,
I've got the same problem when I import a MOV, Quicktime Reference from Avid.
I always work with this files in TMPGEnc Works 5, but now moving to TMPGEnc 6 I can't.
As I import this MOV I got "The An error occurred in the DirectShow File Reader bridge system terminated abnormally (5)"
Then as click OK, I got "Access Denied: error code 0x80070005"
Anybody can tell me what's going on?
Thanks for replies
Roberto -
My trial of 6 just expired, but I don't recall it being a problem. (I'm sticking with 5 for the time being because I see nothing new in 6 that I need.)
A few things to try:
1) re-install Quicktime
2) create a simple avisynth script such as:
QTInput("myfile.mov", audio=1)
ConvertToRGB()
and load the .avs
3) Make sure your QTRef includes files of the same dimensions/framerates -- or better still...
4) Do a video and audio Mixdown of your show before exporting as QTRef. -
Hi smrpix, thanks for suggestions.
I will try some of these.
But my question remain: why before with TW5 everything goes right and now with TW6 I can't use QT reference?
Why???
Same Workstation, same files... but...
I hope this is only a bug that Pegasys will fix with next update (because now I paid for something that I can't use!)
Bye
Roberto
Having Problems With TMPGEnc Video Mastering Works
By Larry Blake in forum Video ConversionReplies: 3Last Post: 7th Oct 2013, 22:31 -
TMPGEnc TMPGEnc Video Mastering Works 5 keeps splitting files of 3 & 4 gb
By goingape in forum Newbie / General discussionsReplies: 2Last Post: 29th Jul 2013, 16:48 -
Cannot deinterlace in Video Mastering works (tmpgenc)
By geneariani in forum Video ConversionReplies: 6Last Post: 24th Dec 2012, 11:53 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
an honest look at TMPGEnc Video Mastering Works 5
By deadrats in forum EditingReplies: 8Last Post: 19th May 2011, 19:02
