There is a 3 Gb avi which I would like to make smaller-- small as possible.
The source resolution is 1280x720.
For CRT use that could easily be cut in half if audio and instruction are the primary goal.
Where is best to start: Convert to TS folders and what tool? Convert from AVI to MKV and what tool?
A quick google search shows a free program at Cnet but it appears to have baggage in the
way it handles the media and I'll not use it. Recommendations from VH freeware preferred.
Hello Baldrick and all.
Vidcoder is based on Handbrake so either should work, yes? I had not done such a conversion
using Handbrake previously and just learning how to use it.
I've had vidcoder on email updates for what seems like years now but rarely communicate with the Sourceforge forum.
I just want to make the content smaller-- no DVD necessary and VH helped me with one of those a short time ago.
What is a reasonable size to reduce to since the Constant Quality scale is logarithmic? -
I often do what you're doing, but my motivation may be different. I usually re-encode,
(so that it plays in a standaone dvd player). Watch the thing once,
then delete. I can either encode it to DVD or xvid/divx (I use DVD-RW's).
If you plan to keep a copy on the PC indefinitely, why not just keep the original?
Second, you did not mention whether you need an SD copy (as I do in my example above)
Your intention for the file should guide you to the answer, once you consider the usage. -
I'll give it a whirl and try the conversion. My HD space is not unlimited. It's a good test even if I do not keep it long.
For Handbrake or Vidcoder, if it involves more than loading the file as the source and giving it a new name and size, I'll be back with additional questions.
As always my thanks to those who answer at VH. -
This operation as described was successful. With no alterations of settings in Handbrake, the most significant of which is Constant Quality default 24 the 3.1 GB file of a simple lecture set with
H265 in Hb and mkv container was processed to 776 megabyte. The job took a little over 10 hours.
Some experts in reducihng file size warn of this time increment to process. If the Constant Quality
was increased (even smaller size) the logarhythmic nature of the process would likely take a factorial longer.
Have I missed something in Hb or Vidcoder which would predict the size of the output file?
Please say if there is and what the downward limit would be regardless of the time it took to make it.
I think I tried to really push one of these down even less and got a bad or 'blank' result-- can't remember exactly. In other words I'd like some warning as to whether the process will succeed or not... some calculator tool perhaps? -
Usng CQ or CRF does leave the final size somewhat unpredictable, this is its nature.
If you need a specific size, you'll have to do 2-pass.
How can determine the used coding method of an avi file? Single pass or two
By molngab in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2015, 11:46 -
Best method to remux an FLV (AVC/AAC) file
By KeyMs92 in forum Video ConversionReplies: 13Last Post: 7th Sep 2013, 00:09 -
How to resize and convert MPEG-2 file so I can work with them in PrPro CS4?
By tomchook in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2012, 11:02 -
Any method to bring back a compressed video file
By nusratjaveid in forum Newbie / General discussionsReplies: 6Last Post: 18th Jan 2011, 00:45 -
Convert MPEG-2 to avi./ QUERY...Best method please
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2010, 14:06
