I've followed the help guide ( dvd2vcd ) and everything is working great.
I am having one problem with the process. My computer freezes up during the DVD2AVI tranfer. Is this due to lack of memory or processing speed? I got 128 RAM and a 750 AMD processor. When I tried to convert all 5 vob files it would freeze up 30 seconds into the transfer. I started to do them one at a time and everything was super until I started the third VOB. My guess is lack of memory or processing but maybe I'm wrong and hopeing I can get some answers. Thanks guys. Josh
Results 1 to 9 of 9
One other question. Since I'm doing the VOB's 1 at a time when ever I select the audio do I select track 1 with VOB 1 , Track 2 with VOB 2 , ECT..... Josh
Nope track 1 for each vob, or track two, or track three
It sounds like the third vob may be corrupted so try and get it again if you can.
what's this "transfer".... aren't u trying to create a .d2v project file w/ dvd2avi so u can frameserve into tmpgenc? if that's the case, you do this w/ all the vobs at once....
His problem was that DVD2AVI wouldn't do all the vobs at once. As it works on each vob seperately except vob 3 it looks like vob3 is shagged.
errr..then his copy of dvd2avi is fuxored...he should get another one (and not the latest version cuz it has audio sync problems)
Thanks for your help guys. I beleive I'm using the 1.82. I am trying to create a d2v file so I can frameserve it. I believe I don't have the memory to support to process. I'm gonna wait until I load my computer to the max with RAM and then continue to process.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 20th Aug 2010, 00:11 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
DVD2AVI/DGIndex Aspect Ratio Problem (Long/Stretched Faces, etc)
By munkeyman in forum DVD RippingReplies: 7Last Post: 19th Feb 2010, 10:47 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
How to frameserve (dvd2avi / VirtualDub / Avisynth / VFAPI)
By Truman in forum User guidesReplies: 32Last Post: 20th Nov 2007, 09:38
