Hello all,
As it says in the title, I am seeing the combing effect (as well as some stutter) on my Samsung UE40F6500 smart TV when playing a 1920x1080 50i h.264 (mp4 container) file, and only on this TV, plays perfectly on PC, on another (smaller) Samsung smart TV i own, as well as on a hardware media player (Lacie).
Taking into account the problem only occurs on the one specific TV, I am assuming there are no problems with the files itself.
So I was wondering if any of you may have experienced the same issue on Samsung TV's and possibly find a solution to this problem. I have been playing around with the TV's settings like ie. MPEG noise & digital noise filter, as well as update the TV's firmware to the latest version, but unfortunately, to no avail...
Are you sure it is actually an interlaced video?
H.264 in mp4 could be interlaced but it is highly unusual.
It is more likely the video was badly interlaced before transcoded or reencoded to H.264.
An mediainfoxp view will give us the information.
I capture these files myself, the files are interlaced as is the source. They are the untouched files that come out of my hardware H.264 encoder and they play fine on any other device I own.
Code:General Complete name : E:\_capture\Untitled 01.mp4 Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 11.7 MiB Duration : 10s 5ms Overall bit rate mode : Variable Overall bit rate : 9 807 Kbps Encoded date : UTC 2015-05-29 10:27:01 Tagged date : UTC 2015-05-29 10:27:12 Writing library : Apple QuickTime Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 10s 5ms Duration_LastFrame : 5ms Bit rate mode : Variable Bit rate : 9 540 Kbps Maximum bit rate : 17.1 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Interleaved fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.184 Stream size : 11.4 MiB (97%) Language : English Encoded date : UTC 2015-05-29 10:27:01 Tagged date : UTC 2015-05-29 10:27:12 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 10s 5ms Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 309 KiB (3%) Language : English Encoded date : UTC 2015-05-29 10:27:01 Tagged date : UTC 2015-05-29 10:27:12 Other ID : 3 Type : Time code Format : QuickTime TC Duration : 10s 5ms Time code of first frame : 00:00:00:00 Time code, striped : Yes Title : time Language : English Encoded date : UTC 2015-05-29 10:27:01 Tagged date : UTC 2015-05-29 10:27:12
How can i downcovert 1080 50I HD to PAL SD with best quality?
By hackerdd in forum Video ConversionReplies: 0Last Post: 12th Sep 2012, 23:22 -
convert 50p and 59.94p 264 to 1080 25i and 1080 29.97i
By wiseant in forum Video ConversionReplies: 8Last Post: 13th Aug 2012, 17:02 -
1080 60i to 1080 50i
By spikespiegel17 in forum Video ConversionReplies: 13Last Post: 15th Jun 2012, 11:08 -
Signal System : 1080/50p , 1080/50i on HDC-SD700
By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Sep 2010, 09:11 -
Postprocessing 1080/50i - stabilizing?
By v1ru5 in forum Newbie / General discussionsReplies: 4Last Post: 4th Sep 2010, 15:06
