I need a program which will capture still frames from .MTS .MKV .MP4 similar to VirtualDub handles .avi frame capture.
i.e. it should allow me to scroll through the video rapidly and capture still frames to the clipboard via a keyboard shortcut. Thanks in advance to all for their help![]()
Have you tried use the ffmpeg input pluing for virtualdub? You can then import many video files directly in virtualdub.
You can install the Virtualdub AIO to get virtualdub with the ffmpeg input plugin. Or get several plugins from http://ale5000.altervista.org/virtualdub/plugins/ -
Thank you Baldrick. I loaded Virtualdub AIO, and it did indeed allow me to load .mts .mkv and .mp4. It would allow me to capture still frames from MP4, however the frame capture command did not work with .mts & .mkv. The clipboard would simply be empty.
I have tinkered with Daum Potplayer and it does allow still frame capture of nearly any video format it will load. That said I prefer Virtualdub, as I can rapidly scroll through a video and quickly copy a specific still frame to the clipboard. Thanks again!
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 01:43 -
Convert MTS and MKV to MP4
By Dragonchaser in forum Video ConversionReplies: 10Last Post: 24th Jan 2015, 07:24 -
Is there a program similar to TMPGEnc for .mp4 and .mkv files?
By Shinjikun in forum Newbie / General discussionsReplies: 5Last Post: 9th Sep 2012, 14:15 -
MTS source - need to deinterlace, resize, encode h264 and make MKV or MP4.
By ibobak in forum Video ConversionReplies: 4Last Post: 25th Jun 2012, 11:59 -
VirtualDub: Working with MKV & MP4 (frame jumps, RGB decompression etc.)
By pokepika in forum Video ConversionReplies: 4Last Post: 21st Sep 2011, 19:28
