I have an AmazonBasics 60-Inch Lightweight Tripod.
I used it on Sony HDR CX-440, it works great when it is steady and not rotate or move around.
Any recommendation video tripod with smooth direction of rotation left/right? My current one it give a shake or I have to force it to rotate but it is not smooth. I like with easy snap on & off.
Thanks.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 22 of 22
You need to look at "fluid head", professional tripods. Minimum cost I've seen for decent ones is ~$270USD (goes up to >$4000 for best ones. Yes, that much). Manfrotto, Vinten, Sachtler, O'Connor, Miller...
Scott -
I can recommend this one for smooth pans: http://www.bhphotovideo.com/c/product/150608-REG/Slik_615_504_504QF_II_Tripod_System.html
Good quality construction, and at a more reasonable price than some of the more 'famous' names.... -
I like Slik and all (have a great monopod of theirs), but one word of warning: It has been my experience that if you want to have consistently "still", stable shots (aka lacking in tripod motion blur), you should always use a tripod that is rated for at least TWICE the maximum weight that is actually to be used on it.
So, that suggested tripod would then really only be rock-solid for <~5 Lbs. This amounts to: light DSLRs (with few, if any, attachments) and point & shoot consumer camcorders and GoPro/sportcams and smartphone cams.
Your Sony HDR CX-440 should work as long as you don't have much accessories on it (smaller battery OK, but not the larger aftermarket ones, no separate audio or even boom mike, no recorder/monitor...). And watch the cabling if you are plugged into AC/mains power.
Still cannot vouch for the "fluidity" of that model, though.
Scott -
Another advantage to getting a good fluid head, even for a light camera, is that it adds a perception of "stately weight" to the movement and comes across as a more polished, professional production.
With respect to camera movement on a tripod, some advice:
1. Don't do it, unless,
2. you have to move it to prepare for a new shot, or,
3. you want to do the once in awhile panning shot.
~ and no, once in awhile does not mean once every half minute! ~
More importantly, never, ever use one single camera unless you are documenting the walks of a single snail.
Most people will disagree with you,one camera is good enough unless you are shooting movies or tv series.
A good tripod is there to get a stable shot, it is not there to create 'dizzyfying' psychedelic pans every three seconds.
Remember the action should be in the scene or in the cuts definitely not in the camera movement.
There are obviously exceptions, a handheld closing up on a face can cause a great dramatic effect, pans can be used to to reveal something surprising or create an introducing or overview giving effect to a new setting.
But again those things only apply once in awhile.
Unless it is a very short clip a single shot recording pretty much guarantees your viewer zones out after 10 minutes, it's unpalatable.
This is all common sense, filming 101.
Tell that to Orson Wells (Touch of Evil opening) or Alfred Hitchc*o*c*k (Rope) (stupid autocorrect!) or the thousands of followers who have used single-shot & single-shot-like tripod & crane moves to wonderful effect!
You're just digging your own hole deeper, especially when you are clearly out of your element...
Scott -
Academy award level filmography....
Perspective folks!
We are trying to help people who use Sony HDR CX-440 and AmazonBasics 60-Inch Lightweight Tripod like equipment.
Have it anyway you like criticizing me but I see far too many examples of amateurs making the same mistakes all the time:
- not using a tripod
- constantly moving the camera on the tripod in an almost 'psychedelic' fashion
- zooming in and out just for the sake of it
- bad sound
- bad camera position
- endless single shot recordings
I am just trying to help here!
I really like my Davis & Sanford MAGNUMXG13 Magnum Grounder tripod. It's very smooth, quiet, extends to 6' and has a 10 year warranty.
Looking to protect my video camera on the tripod
By csmith3pmg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Mar 2015, 10:06 -
Is this a good tripod for a camcorder?
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Feb 2013, 17:02 -
Fine tuning for tripod ball-head?
By acusman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 10th Apr 2011, 19:28 -
Tripod backpack recomendations?
By Vakharn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 12th Jan 2011, 19:54 -
How can I correct a tripod-shot video with vertical vibration?
By pete2004 in forum RestorationReplies: 1Last Post: 16th Aug 2010, 11:26
