My apologies in advance if Im posting this in the wrong place.
Let me say first that I have almost zero experience with any video editing.
My problem - I'd been using an addon for Firefox to capture videos from youtube. Sometimes this works flawlessly, others it splits the video and the audio into separate files. A Video file and a sound file of various formats.
What Im trying to find out is, if there a program free or paid, that will allow me to merge them back together again? OR if there is another way I can Merge them into one file.
Any suggestions at all would be much appreciated!
thanks
Clockwork: Video DownloadHelper has some sort of screen capture thingy.
L.Frost: You can use FFmpeg to join the files with a command like:
If you would like a graphical interface you could use FFQueue. Create a preset with video codec = copy, audio codec = copy. Create a job with video as input #1 and audio as input #2, select the preset and the name for the output file, save job and start queue and that's it.Code:ffmpeg -i "path/to/video" -i "path/to/audio" -map 0:0 -map 1:0 -c:v copy -c:a copy "path/to/av-joined"
I'm the developer behind FFQueue. My posts might reflect this! ;-) -
Or use a multiplexer like mkvmergegui, load your first video file and then click append to join the rest files. Mux/make a new single mkv.
But please give more information about the video files if you want more ideas.
Big Noob here, need help spliting AVI FILE
By MisterBasketball in forum Newbie / General discussionsReplies: 5Last Post: 10th Jan 2015, 12:51 -
Merging an image in audio file
By vijay123 in forum Video ConversionReplies: 36Last Post: 20th May 2013, 12:58 -
Merging multiple parts of one mp4 file into one file
By vaultedskies in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2011, 10:08 -
Merging multiple files as one video file?
By mikehende in forum Newbie / General discussionsReplies: 5Last Post: 10th Nov 2011, 07:28 -
Cutting/Merging MKV file - Mkvtoolnix
By FMFIA in forum EditingReplies: 1Last Post: 15th Aug 2010, 01:47
