Sony Blue Ray/ Disk DVD Player, Model BDP S1200
Was working perfectly. It is recognised on the TV Screen via HMD1 connection. However a screen comes up as follows: 'Do You Want to set your Internet Settings Now.'
It gives me the options 'Yes' and 'No'. 'No' is already selected. So I click on the option with my remote control. However each time I click on 'No' the same screen with the same options re-appear.
What I have tried: 1. I have tried it with another TV , but the same result. 2. I have tried it with a different HDMI cable, but the same result. I brought it into the shop in which I bought it (it is under guarantee). I forgot to bring the Remote. They produced a similar remote. IT WORKED WITH THAT REMOTE.
I retried with old remote at home, but with negative result. i changed the batteries in the remote, but negative result.
The final thing: This first occurred when i was playing a DVD after it freezed at a frame (got stuck). I removed the DVD, cleaned it and reinserted it. It was at this point that the problem arose - I never got beyond the message 'Do you want to set the Internet Settings'
Results 1 to 1 of 1
remote control DVD player
By Franci in forum Software PlayingReplies: 1Last Post: 16th May 2015, 17:47 -
A remote goods for both Sony BDP-BX57 BD player and STR-DE597 receiver ?
By SingSing in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Aug 2014, 23:06 -
HELP - Lost Remote Control for DVD Player
By Jezza82 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 16th Feb 2013, 20:17 -
Remote Control Problem with new Sony SR500H DVD player
By Bass Cadet in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2011, 13:56 -
Sony RDR-HX710: remote not working, how to access recordings?
By disconnekt in forum DVD & Blu-ray RecordersReplies: 10Last Post: 4th Feb 2011, 04:01
