    Oct 2013
    brasil
    Hello guys
    i´m having some trouble with resume action in DVD LabPro.
    I built a dvd containing 2 movies.
    On the 1st one it goes to a full movie with 2 audio tracks
    The other movie is a trailler with one audio track.
    The problem is whenever i choose the play button it plays the movie with the selected audio track.
    But, after it, if i go back to the main menu and select the trailler. The things go wrong
    It plays the trailller, but when it comes back to the main menu so i can play agan the movie, it keeps playing the trailer insetad. (Even when i click the play button and not the trailer menu button)
    I have no idea what i´m doing wrong or how to fix it.
    The goal is i can whatch and resume the main movie with the desired audio track and also allow to whatch the trailer and go back to the movie under user´s choice.
    Can someone help ?
    Best Regards
    guga
  2. movie should have direct link from main menu (root) and link to chapters,
    you do not need to play it all for your DVD ?
    if more titles, you need to select audio track in pre-command section for particular title (movie or trailer), so trailer sets always first audio but audio for movie could differ, you have to dedicate one GPRM and always store the particular audio track there and select it always in title pre-command section
    even if you jump into chapter, pre-command section is always run
