When attempting to convert DivX to SVCD or DVD with the standard templates in TMPGEnc, I get no sound at all in the output file.
One Divx that I tried to convert has DivX Video and Fraunhofer IIS MPEG Layer-3 Audio.
Any ideas... this should be an easy one...
I would suggest encoding only the video in TMPG and convert the audio seperate and then bring together with bbmpeg.
get your video encoded alone and it will give you an mpv or m1v file.
for the audio, Vdub and direct stream copy then save as wave. then use besweet to change audio from wav to mp2.
then get bbmpeg and it will easily bring the 2 together, or you could try and multiplex with TMPG.
go here for more on what I am talking about -
I think I got it... I used VirtualDub to extract the audio, then used the resulting wav file along with the DIVX AVI to ouput MPEG2 using TMPGEnc's DVD(NTSC) template.. I tried a sample and it seems to have worked. I tried this once before and got really poor, choppy audio... but I think that I had extracted the audio to the wrong bitrate that time. I think I used 44100 and should have been using 48000.
Converting AVCHD(MTS) to MPEG2(DVD)
By manyoo in forum Newbie / General discussionsReplies: 5Last Post: 4th Aug 2011, 02:10 -
Is there a faster way of converting MKV to mpeg2 for DVD than FAVC?
By Onceler2 in forum Video ConversionReplies: 1Last Post: 31st Jul 2011, 16:55 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 09:23 -
Converting DVD to single MPEG2
By nagihcim1 in forum Newbie / General discussionsReplies: 4Last Post: 5th Sep 2007, 15:55
