I want to record my vhs tapes recording in dvd format.For best video quality which is best Tv tuner card or video capture card.
If you're looking to get the best VHS caps the capture device is the least of your concerns. The (s)vhs deck, a line time base corrector, a full frame tbc, and advanced filtering are all more important. There are hundreds of threads here regarding all of those.
The Colossus or HD PVR will work (they're primarily for high definition capture) but there are much cheaper and better alternatives. You want a capture device that can capture raw YUY2 (or other YUV 4:2:2 chroma subsampling) with a lossless codec. Avoid the ultra cheap (<$10) devices like the EasyCap clones.
http://www.amazon.com/Hauppauge-610-USB-Live-Digitizer-Capture/dp/B0036VO2BI/
http://www.amazon.com/EZCAP-TV-Converter-Camcorders-Satellite-Supports/dp/B003YGJLWU/
I don't know what's available in Pakistan.Last edited by jagabo; 25th May 2015 at 11:30.
Recovering noisy VHS recording
By Beast8 in forum RestorationReplies: 1Last Post: 14th Jan 2015, 09:07 -
Recording VHS to VHS?
By hartshapedbach in forum Capturing and VCRReplies: 5Last Post: 1st May 2012, 19:49 -
Recording from Vhs cassette With best video Quality.
By nusratjaveid in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2011, 20:23 -
Vhs to dvd recording
By JAYHAWK1970 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 20:21 -
Question about VHS recording
By gejlvem in forum Capturing and VCRReplies: 1Last Post: 12th Jan 2011, 18:24
