  1. Sorry for this simple question. I am a newbie to multiAVCHD.
    1) I am simply trying to join multiple MTS files into 1 file.
    2) I did it one almost by accident, so I know I can, but I can not seem to do it again
    I believe I clicked on the "Join MPG/M*TS/JPEG, selected the input folder for the videos, they load, but now I am stuck. What am I doing wrong? I'd rather not mess with tsmuxer and eac3to individually. HELP! Thanks to All!
    Why do you have to use eac3to when joining with tsmuxer? Add the first mts and then click join for the rest of the mts files. Output as a new ts or m2ts.
  3. Baldrick, Thank you for your prompt and correct reply. So, I already learned something. It did work, and produced an m2ts video.
    Q1) Is an .m2ts the same as an .mts? I did change the extension to .mts and it did open.
    My issue there is that I had to add each file to be joined. It would be time consuming if joining dozens of files.
    Q2) I thought that multiAVCH would automatically join all files in a given directory. Will it do so, and how would I accomplish that.
    Thank you to all in advance.
