My LOGIK 24" TV will play video from a USB dongle, However I cant seem to get the format correct.
The instructions say that the TV supports playback MPEG1/2/4 and AVI, however MP4 doesnt work, I am aware that MP4 is a container so has various different fromats within it, but when I convert a DVD file, a Vob file in a TS folder, to MP4 using AVS video converter, it wont playback on the TV, what settings would you folks recommend to use in AVS Video converter to get the right file format. Im in a Region 2 Pal country if that has any effect one the outcome....Thanks for any advice
In the settings make sure you are using the xvid codecs,read your manual to see if it supports divx as well or just one of them.
Samsung E360 DVD USB video playback autoplay autorepeat??
By nerys in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Mar 2015, 10:19 -
Best format for watching video on TV via a USB
By efiste2 in forum Newbie / General discussionsReplies: 5Last Post: 1st Sep 2014, 21:25 -
Most Common video format for usb tv
By d_unbeliever in forum Video ConversionReplies: 6Last Post: 20th Mar 2014, 17:56 -
Samsung BD-D5500 Audio/Video DeSync During MKV Playback Over USB
By Anonymous8443434 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 11th Jul 2012, 21:34 -
Sony Bravia 40" BX400 - USB Video Format issue
By dreamcast in forum Video ConversionReplies: 4Last Post: 16th Oct 2010, 08:49
