Hitman800,
http://www.divx-digest.com/software/subtitle_workshop.html
I just found that tool, it is supposed to join subtitle files without editing the text file manually. Until now I have known only the hard way, that means editing the text file line by line. So if you have splitted your subtitles accidentally, you can join them again. Then you can split the file into 3 parts.
Adding permanent subs requires reencoding. I tried to explain the method above. Did you read the thread?what do I do now to get them permanently on the SVCD? Which program shall I use?
If your player support SVCD subs or CVD subs, you can convert your files to that format with MaestroSBT and mux it to the MPEG with winsubmux
Download a SVCD sample here.
Results 31 to 45 of 45
Thanks.
Yes, I read the thread but found it very technically
I will try that tool, you're referring to.
Hitman800 -
Please Help...
I am stuck at the 1st scenario. It read
Let's start VirtualDub, select file > open the video file.
Select video > filters > add vobsub
A configuration dialog will pop up......
I tried open the video file by clicking on file > open video file. It game me an error.
"Coulden't locate decompressor for format 'Div3' (Microsoft High-speed MPEG-4 V3 [Hack
iviX Low-Motion])
VirtualDub requries a Video for windows (VFW) compatible codec to decompress video. DirectShow codes, such as those used by Windows media player are not suitable.
What the error ? What should i do to solve it. Thanks... -
I've been playing with vobsub+avisynth for creating video clips with subtitles from DVD rips. I found that the avisynth plugin from vobsub 2.18 doesn't seem to work correctly in the YUY colorspace, the subtitles got added just fine but some of the colors in the rest of the picture were messed up. I had to do a ConvertToRGB() first to get good results. I haven't used older versions or the other vobsub plugins (textsub, VirtualDub, etc.) so I can't say if they have the same problem. It might be helpful to add a note about this to the guide.
my problem is when i start to install vobsub for virtualdub and textsub for virtualsub and it asks to select the directory where vistualdub is installed at... it just isn't installed! i just have the .exe file and usually i just click in it and the program opens. but if i select the directory the .exe is in, it just won't work. i get an error saying it's not a valid path for virtualbub, so the plugins won't be installed.
how do i correctly install virtualdub or is there another way to fix that?
thanks!
take care. -
ok, i found out, well, sort of... i'm just adding manually the pluggins.
anyway, i've goit another problem now (what else is new?). i did all of the guide said, and have my mpg file now. the problem is that it won't open. i9 tried changing the player, but it just doesn't. plus, my computer turns off and re-start by itself (using all players).
anyone know what´s wrong?
i forgot to say that when i open the original movie (without the subtitles) an warning about an improper VBR audio comes in, and it says that will re write the audio header with standart CBR and that this may introduce up to 178742 ms of skew from the video stream. i don't know what that means, but maybe this is important.
and... when i tried to open the subtitled file in tirtualdub to scan for bad frames, it gave this error: "MPEG import filter
ack synchronization error".
take care. -
I just wanted to know how to make the karaoke feature function in vobsub's submux. I use *.ssa, and the commands work when hard encoded in VirtualDub, but when I use the same *.ssa and mux it with the avi, the file would play OK, but but the karaoke part is not moving at all. The primary color is stuck on one half of the line and the secondary color on the other half
is this a bug, or is it simply impossible to mux karaoke features? I just wanted to know since I only wanted to soft encode my avis.
Thanks a lot! ^_^ -
I have used the "How to add permanent subtitles with VobSub" guide to add subtitles to a vcd made from a DVD-Video. Under Scenario 1, the guide write open the video file. Which file? Which file extention? Should VobSub/Virtual Dub be used after Smartripper and before DVD2AVI? How is the correct order?
Thanks in advance!
Mr. Andersen from Denmark -
I'm on this step right here and I can't seem to get it right. I got the video open, I went to video > filters, but can't seem to find where the add vobsub is. I went to add filter and didn't find where the vob sub is.
Select video > filters > add vobsub -
It's my first time ripping a DVD and I am basically have the same question as Jan65. I've ripped the dvd to vob using smartripper, but i'm not sure when to incorporate the subtitles before i make it into a VCD. If someone could clarify this that would be great.
Originally Posted by Truman
how can I add subtitles below the movie in the black zone?
how can I add selectable subtitles in SVCD (bitmaps)? -
I have a film with subs which already inside.
Can I delete them anyhow?
Thanks -
Hi Truman,
I have problem with scenario 1.
A did all as what you told, until
"Click start Frame server"
A windows pop-up and ask frame server name.
and i click okay, a window asking me to save vdr or avi. and save. and it did nothing.
no movement at all. what should i do next?
everything
Do i do anything wrong? -
hi, i was wondering if anyone could help me out, i followed this tutorial and did it successfully, but when i add the subs to the movie, there is no sound, so if i burn that new avi to a dvd, well convert it first then burn it, it wont have any sound, can sumone please tell me how to add subs and keep the sound with the avi file? thanks so much in advance
Add permanent subtitles to S/VCD,DVD,AVI with ffdshow/vobsub
By Baldrick in forum User guidesReplies: 74Last Post: 4th Oct 2011, 04:11 -
Add delay to vobsub subtitles.
By therock001 in forum SubtitleReplies: 2Last Post: 18th Mar 2008, 16:41 -
Permanent Subtitles with VobSub
By daniscp in forum EditingReplies: 0Last Post: 18th Dec 2007, 08:42 -
How do I add or edit permanent subtitles
By VidHunter in forum MacReplies: 19Last Post: 29th Nov 2007, 14:55 -
Add permanent subtitles to an AVI file using a MAC?
By blueblitz in forum MacReplies: 1Last Post: 15th Oct 2007, 05:10
