I want to frameserve VirtualDub to TMPGEnc, I haven't been able to... I tried a search, but didn't find anything useful. Would there happen to be a tutorial anywhere? Thanks
http://www.vcdhelp.com/virtualdubframeserve.htm
But I suggest to start with proxy off. It depends on the TMPG version, your OS and whether you use a 2nd frameserver as well, e.g. VFAPI.
It may be a little tricky, some need the proxy mode, some do not.
Best way is to tell us what you are doing. -
I want to use it to cut the commercials out of a tv episode before encoding to VCD/SVCD without having to save a new avi, I'm low on HD space.
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 11:36 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Windows Color Profiles ignored by TMPGenc, VirtualDub, etc. ?
By sanlyn in forum Video ConversionReplies: 13Last Post: 28th Jun 2008, 09:42 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
