Hi,
I'm very pleased to have finally found a free video converter after failing to find a 'free' converter that didn't require a subscription fee - wondershare does a a great MP4 to VOB -
But,the XviD4PSP 5 does seem to take hours (24!) to encode a file,and I have no idea what any of the features are meant to do, although I've guessed I need to convert it to a MPEG2 PAL file which is what most european dvd operate with.
The video has completed and saved in a temp folder Encoding video to: C:\Temp\0000.m2v
MPEG2 Q1.0 720x576 23.976fps (171603 frames) but the audio data is now being completed separately, slowly, Encoding audio to: C:\Temp\0000.ac3
AC3 192kbps 2ch 16bit 48000khz
Can I ask if after it's completed whether I will be able to burn the MPEG2 file to a dvd, probably using wondershare, and if AC3 is an appropriate setting for the file?
full details copied here:
PLATFORM
OS Code: Microsoft Windows NT 6.1.7601 Service Pack 1
OS Name: Windows 7 Home Premium Service Pack 1 (x64)
Framework: 2.0.50727.5485 (v4.0)
AviSynth: AviSynth 2.60, build:Feb 20 2015 [03:16:45]
CPU Info: AMD E1-1200 APU with Radeon(tm) HD Graphics (~1397), 2 core(s)
RAM Total: 3686Mb
Language: ENG (1252, ".")
SystemDrive: C:
XviD4PSP
Version: 5.10.346.0
Created: 12.02.2015 12:46:56
AppPath: C:\Program Files (x86)\XviD4PSP 5
TempPath: C:\Temp
FILES
videoplayback.mp4 >
videoplayback.mpg
TASK
Format: MPEG2 PAL
Duration: 01:59:17:282 (171603)
VideoDecoder: DirectShowSource
Resolution: 1280x696 > 720x576
Aspect: 1.8391 > 1.7778
VCodecPreset: MPEG2 HQ Ultra
VEncodingMode: Quality
VideoCodec: h264 > MPEG2
VideoBitrate: 1416 > Q1.0
Framerate: 23.976
SourceType: PROGRESSIVE
FieldOrder: UNKNOWN
AEncodingPreset: AC3 192k
AudioCodec: AAC > AC3
AudioBitrate: 192
Samplerate: 44100 > 48000
SamplerateModifier: SSRC
Channels: 2
Normalize: 100%
Accurate: 10%
Gain: 0.893
SCRIPT
Import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\AudioFunctions.avs")
Import("C:\Program Files (x86)\XviD4PSP 5\dlls\AviSynth\functions\VideoFunctions.avs")
DirectShowSource("C:\Users\TOSHIBA\Desktop\videopl ayback.mp4", fps=23.976, convertfps=true)
SSRC(48000)
ConvertToYV12()
###[FILTERING]###
###[FILTERING]###
Lanczos4Resize(720, 556)
AddBorders(0, 10, 0, 10)
AmplifydB(0.893)
AUDIO ENCODING
aften.exe: -b 192 - "C:\Temp\0000.ac3"
VIDEO ENCODING
ffmpeg.exe: -y -i "C:\Temp\0000.avs" -threads 2 -r 23.976 -vcodec mpeg2video -an -qscale 1.0 -maxrate 9200000 -bufsize 1835000 -bf 2 -mbd bits -cmp 2 -subcmp 2 -mbcmp 2 -ildctcmp 2 -precmp 2 -skipcmp 2 -trellis 1 -vtag MPEG -flags +umv -aspect 1.778 "C:\Temp\0000.m2v"
Closed Thread
24 hours?
You would (IMO) be better off with AVStoDVD if you want to make a DVD. You've got PAL resolution but not PAL framerate for the video. The AC3 audio is fine for DVD.
Remuxing MP4 with AC3 audio - What to Use?
By THRobinson in forum Video ConversionReplies: 5Last Post: 13th May 2014, 03:29 -
MPEG StreamClip - H.264 MP4 w/AC3 audio loses audio
By the_wallcrawler in forum Video ConversionReplies: 5Last Post: 25th Jan 2014, 04:05 -
[Help]Adding AC3/DTS Track in a MP4/AVI file
By new93 in forum AudioReplies: 10Last Post: 20th Nov 2012, 11:07 -
How can I convert a mpeg2 and ac3 file set into a mp4?
By woppyvac in forum Newbie / General discussionsReplies: 10Last Post: 5th Apr 2012, 09:01 -
DVD to .MP4 for Iphone using XviD4PSP audio sync issue
By Tearren in forum Video ConversionReplies: 4Last Post: 6th Jun 2010, 22:14
