Debated asking this here or somewhere more attuned to Windows issues, but here is so friendly I thought I'd give it a go. This is the 'computer' section, after all.
Sometimes it works right, if I issue three successive 'winkey-e' commands and then two alt-F4 commands, I'm looking at the last remaining explorer window SELECTED.
But if I run quickpar and then cmd.exe and then type exit (alt-F4 won't close cmd.exe) and then press alt-F4, I'm looking at the shutdown/reboot dialog as removing cmd.exe does NOT make the previous quickpar window 'selected', even though it's on top.
Just tried this on my XP machine and it doesn't work there either. But if I have cmd.exe running and minimized and I run quickpar then unminimize and then minimize cmd.exe, XP shows quickpar selected, Win7 does not.
What I'm hoping is that someone has a small program that can query windows maybe every tenth of a second for what window is on top and force it to be selected.
Or any other useful idea. I just get so frustrated when I'm working in a window, open a second to check something, close it and not be where I previously was with the window I'm working in being selected.
Any ideas or fix?
TIA,
pcG
??? Why aren't you just using [Alt+Tab] (hold down/repeat Tab, if necessary) to get exactly to the window you want? That's available in ALL versions of Windows (including 8.x IIRC).
Scott -
Seems quite straightforward to me. Open window b on top of window a, close b and you should be back at window a.
but you're not and I automatically try and use the scroll wheel or start typing and nothing happens ... and then I click on the title bar, which is much more efficient that alt-tab.
I want windows to work right and I just want to know if someone cares enough to have created a workaround for a glaring lack of professionalism on microsoft's part. You go ahead and put up with added effort like it's aok with you, me, I'm peeved that proverbially 'taking a step up and taking a step down' doesn't land you on the step you started on.
microsoft can (as my example showed) do this correctly, they just don't even try most of the time.
pcG
Now, excuse me, I have to go eat some crow in another thread (artifacts and such) -
It strikes me that there's a better way of saying what bothers me about this problem (and I assure you, it IS a problem).
For an operating system called "window"s, if there is one or more window open, then there should ALWAYS be a 'selected' window.
Open a window and it is perforce 'selected'. Then open a second window and it now is 'selected'. So, when you close the second window, there should be a 'selected' window and if that were true, then it would have to be the one on top, the previously 'selected' one is once again. but it's not.
It just boggles the mind that one or more windows are open and NONE OF THEM are selected.
I'm sorry, that just seems all kinds of wrong to me, like consistency and reliability mean nothing ... unless you consider who we're talking about, I suppose.
I can't be the first person to notice this glaring inconsistency, so I'd think with 95% market share, someone with programming skills might have at least attempted a workaround.
Maybe not. sigh ...
pcG -
The desktop and the taskbar are also windows. If another window looses focus on account of the being closed, I think the taskbar receives the focus by default. I think technically, the taskbar is always the top window. [Edit] ...unless maybe some other window is set to "always on top", but I haven't experimented with that to find out.
That's correct.
Code:[C:\] =>cmdow Handle Lev Pid -Window status- Image Caption 0x010014 0 252 Res Ina Ena Vis csrss #32769 0x080274 1 992 Res Ina Ena Hid explorer BaseBar 0x27026A 2 992 Res Ina Ena Vis explorer MenuSite 0x55024E 3 992 Res Ina Ena Vis explorer SysPager 0x320294 4 992 Res Ina Ena Vis explorer ToolbarWindow32 0x05006E 1 992 Res Ina Ena Hid explorer BaseBar 0x050070 2 992 Res Ina Ena Vis explorer MenuSite 0x050074 3 992 Res Ina Ena Vis explorer SysPager 0x050076 4 992 Res Ina Ena Vis explorer ToolbarWindow32 0x960246 3 992 Res Ina Ena Vis explorer ToolbarWindow32 0x190394 1 992 Res Ina Ena Hid explorer tooltips_class32 0x2C0328 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x0803AA 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x2D0254 1 300 Res Ina Ena Hid seamonke Go to last post 0x1B0278 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x0D0256 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x0D0244 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x1902CA 1 300 Res Ina Ena Hid seamonke Enter search term, keyword, or web add 0x1602AA 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x1502C2 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x1302B4 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x200346 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x190388 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x1F0364 1 300 Res Ina Ena Hid seamonke Profile 0x1303FE 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x120390 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x21033A 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x0F03EE 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x1102FE 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x030038 1 992 Res Ina Ena Vis explorer Shell_TrayWnd 0x03003E 2 992 Res Ina Ena Vis explorer Start 0x030040 2 992 Res Ina Ena Vis explorer TrayNotifyWnd 0x030042 3 992 Res Ina Ena Vis explorer 19:40 0x030044 3 992 Res Ina Ena Vis explorer SysPager 0x030046 4 992 Res Ina Ena Vis explorer Notification Area 0x030056 3 992 Res Ina Ena Vis explorer Button 0x010060 2 992 Res Ina Ena Vis explorer ReBarWindow32 0x010064 3 992 Res Ina Ena Vis explorer Running Applications 0x010068 4 992 Res Ina Ena Vis explorer Running Applications 0x34027E 1 300 Res Ina Ena Hid seamonke MozillaDropShadowWindowClass 0x2F028E 1 992 Res Ina Ena Hid explorer SysFader 0x200282 1 992 Res Ina Ena Hid explorer WorkerW 0x10029C 1 992 Res Ina Ena Hid explorer SysFader 0x03025E 1 992 Res Ina Ena Hid explorer BaseBar 0x030260 2 992 Res Ina Ena Vis explorer MenuSite 0x030262 3 992 Res Ina Ena Vis explorer ToolbarWindow32 0x01007A 1 992 Res Ina Ena Hid explorer tooltips_class32 0x1103CE 1 1288 Res Act Ena Vis cmd 5 - CLI - cmdow 0x0B02B6 1 992 Res Ina Ena Hid explorer SysPager 0x04039C 2 992 Res Ina Ena Vis explorer ToolbarWindow32 0x1203CA 1 300 Res Ina Ena Hid seamonke MozillaWindowClass 0x1303F2 1 300 Max Ina Ena Vis seamonke Any program that makes the top window 0x150370 1 992 Res Ina Ena Hid explorer tooltips_class32 0x0F02A8 1 992 Res Ina Ena Hid explorer tooltips_class32 0x18023E 1 992 Res Ina Ena Hid explorer tooltips_class32 0x0F02A0 1 992 Res Ina Ena Hid explorer tooltips_class32 0x270252 1 992 Res Ina Ena Hid explorer WorkerW 0x170248 1 992 Max Ina Ena Vis explorer W:\ 0x160266 2 992 Res Ina Ena Vis explorer WorkerW 0x270272 3 992 Res Ina Ena Vis explorer ReBarWindow32 0x0F0290 4 992 Res Ina Ena Vis explorer ToolbarWindow32 0x100242 4 992 Res Ina Ena Vis explorer WorkerW 0x0F029A 4 992 Res Ina Ena Vis explorer ToolbarWindow32 0x0F0298 2 992 Res Ina Ena Hid explorer WorkerW 0x0F029E 2 992 Res Ina Ena Vis explorer msctls_statusbar32 0x0E02A4 2 992 Res Ina Ena Vis explorer BaseBar 0x100288 3 992 Res Ina Ena Vis explorer ReBarWindow32 0x16026E 4 992 Res Ina Ena Vis explorer ToolbarWindow32 0x120296 4 992 Res Ina Ena Vis explorer SysTreeView32 0x2803FC 2 992 Res Ina Ena Vis explorer SHELLDLL_DefView 0x1203D6 3 992 Res Ina Ena Vis explorer FolderView 0x1E0250 1 300 Res Ina Ena Hid seamonke MozillaWindowClass 0x09027C 1 300 Max Ina Ena Vis seamonke Any program that makes the top window 0x01006A 1 992 Res Ina Ena Hid explorer tooltips_class32 0x1202A2 1 992 Res Ina Ena Hid explorer ToolbarWindow32 0x180292 1 992 Res Ina Ena Hid explorer ToolbarWindow32 0x2A026C 1 992 Res Ina Ena Hid explorer SysPager 0x3202A6 2 992 Res Ina Ena Vis explorer ToolbarWindow32 0x01005E 1 992 Res Ina Ena Hid explorer tooltips_class32 0x0B0384 1 992 Res Ina Ena Hid explorer MCI command handling window 0x0B0312 1 300 Res Ina Ena Hid seamonke WorkerW 0x1B0264 1 300 Res Ina Ena Hid seamonke MCI command handling window 0x1A024A 1 300 Res Ina Ena Hid seamonke MozillaHiddenWindowClass 0x11024C 1 300 Res Ina Ena Hid seamonke DDE Server Window 0x160284 1 300 Res Ina Ena Hid seamonke nsAppShell:EventWindow 0x1A0286 1 300 Res Ina Ena Hid seamonke DDEMLEvent 0x150258 1 300 Res Ina Ena Hid seamonke DDEMLMom 0x160270 1 300 Res Ina Ena Hid seamonke SeaMonkeyMessageWindow 0x01005C 1 992 Res Ina Ena Hid explorer tooltips_class32 0x010058 1 992 Res Ina Ena Hid explorer tooltips_class32 0x01005A 1 992 Res Ina Ena Hid explorer tooltips_class32 0x03025C 1 992 Res Ina Ena Hid explorer ToolbarWindow32 0x010230 1 1700 Res Ina Ena Hid xfilter XFilter Personal Firewall 0x010232 3 1700 Res Ina Ena Vis xfilter OK 0x010234 3 1700 Res Ina Ena Vis xfilter Cancel 0x01022E 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01022C 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01022A 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010216 1 1700 Res Ina Ena Hid xfilter Find 0x010218 3 1700 Res Ina Ena Vis xfilter Find what: 0x01021A 3 1700 Res Ina Ena Vis xfilter Edit 0x01021C 3 1700 Res Ina Ena Vis xfilter Match &whole field only 0x01021E 3 1700 Res Ina Ena Vis xfilter &Match case 0x010220 3 1700 Res Ina Ena Vis xfilter &Up 0x010222 3 1700 Res Ina Ena Vis xfilter &Down 0x010224 3 1700 Res Ina Ena Vis xfilter &Find Next 0x010226 3 1700 Res Ina Ena Vis xfilter &Cancel 0x010228 3 1700 Res Ina Ena Vis xfilter Direction 0x010214 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010212 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010210 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01020E 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01020C 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01020A 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010208 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010206 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101C2 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101AE 1 1700 Res Ina Ena Hid xfilter Find 0x0101B0 3 1700 Res Ina Ena Vis xfilter Find what: 0x0101B2 3 1700 Res Ina Ena Vis xfilter Edit 0x0101B4 3 1700 Res Ina Ena Vis xfilter Match &whole field only 0x0101B6 3 1700 Res Ina Ena Vis xfilter &Match case 0x0101B8 3 1700 Res Ina Ena Vis xfilter &Up 0x0101BA 3 1700 Res Ina Ena Vis xfilter &Down 0x0101BC 3 1700 Res Ina Ena Vis xfilter &Find Next 0x0101BE 3 1700 Res Ina Ena Vis xfilter &Cancel 0x0101C0 3 1700 Res Ina Ena Vis xfilter Direction 0x0101AC 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101AA 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101A8 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101A6 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101A4 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101A2 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101A0 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01019E 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01019C 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010156 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010154 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010152 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010150 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100F8 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100F6 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100F4 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100F2 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100F0 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100EE 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100EC 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100EA 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100E8 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100E6 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100E4 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100E2 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100E0 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100DE 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100DC 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100DA 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0100D8 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0200A8 1 1700 Res Ina Ena Hid xfilter Filseclab Personal Firewall Profession 0x0100AC 2 1700 Res Ina Ena Vis xfilter Static 0x0100AE 2 1700 Res Ina Ena Vis xfilter Static 0x0100B0 2 1700 Res Ina Dis Vis xfilter Status 0x0100B2 2 1700 Res Ina Ena Vis xfilter Monitor 0x0100B4 2 1700 Res Ina Ena Vis xfilter Log 0x0100B6 2 1700 Res Ina Ena Vis xfilter Rules 0x0100B8 2 1700 Res Ina Ena Vis xfilter Settings 0x0100BA 2 1700 Res Ina Ena Vis xfilter About 0x0100BC 2 1700 Res Ina Ena Vis xfilter Help 0x0100BE 2 1700 Res Ina Ena Vis xfilter Exit 0x0100C0 2 1700 Res Ina Ena Hid xfilter LiveUpdate 0x0100C2 2 1700 Res Ina Ena Vis xfilter Button 0x0100C4 2 1700 Res Ina Ena Vis xfilter Button 0x0100C6 2 1700 Res Ina Dis Vis xfilter Button 0x0100C8 2 1700 Res Ina Ena Vis xfilter Button 0x0100CA 2 1700 Res Ina Ena Vis xfilter Button 0x0100CC 2 1700 Res Ina Ena Vis xfilter Button 0x0100CE 2 1700 Res Ina Ena Vis xfilter Button 0x0100D0 2 1700 Res Ina Ena Vis xfilter Button 0x0100D2 2 1700 Res Ina Ena Vis xfilter Static 0x0100FC 3 1700 Res Ina Ena Vis xfilter #32770 0x0100FE 4 1700 Res Ina Ena Vis xfilter Signu&p 0x010100 4 1700 Res Ina Ena Vis xfilter Live&Update 0x010102 4 1700 Res Ina Ena Vis xfilter Slider1 0x010104 4 1700 Res Ina Ena Vis xfilter (T) Total 0x010106 4 1700 Res Ina Ena Vis xfilter &T 0x010108 4 1700 Res Ina Ena Vis xfilter Static 0x01010A 4 1700 Res Ina Ena Vis xfilter (O) Sent 0x01010C 4 1700 Res Ina Ena Vis xfilter &O 0x01010E 4 1700 Res Ina Ena Vis xfilter Static 0x010110 4 1700 Res Ina Ena Vis xfilter (R) Received 0x010112 4 1700 Res Ina Ena Vis xfilter &R 0x010114 4 1700 Res Ina Ena Vis xfilter Static 0x010116 4 1700 Res Ina Ena Vis xfilter (D) D-Scale 0x010118 4 1700 Res Ina Ena Vis xfilter &D 0x01011A 4 1700 Res Ina Ena Vis xfilter Static 0x01011C 4 1700 Res Ina Ena Vis xfilter &Stop 0x01011E 4 1700 Res Ina Ena Vis xfilter Security Level 0x010120 4 1700 Res Ina Ena Vis xfilter Static 0x010122 4 1700 Res Ina Ena Vis xfilter Starttime: 12:10:54 0x010124 4 1700 Res Ina Ena Vis xfilter Elapsed time: 07:29:56 0x010126 4 1700 Res Ina Ena Vis xfilter Bytes in: 117301973 0x010128 4 1700 Res Ina Ena Vis xfilter Bytes out: 12263001 0x01012A 4 1700 Res Ina Ena Vis xfilter Packets blocked: 469 0x01012C 4 1700 Res Ina Ena Vis xfilter Packets passed: 38075 0x01012E 4 1700 Res Ina Ena Vis xfilter Security level: Medium 0x010130 4 1700 Res Ina Ena Vis xfilter Static 0x010132 4 1700 Res Ina Ena Vis xfilter Medium 0x010134 4 1700 Res Ina Ena Vis xfilter Low 0x010136 4 1700 Res Ina Ena Vis xfilter 250K 0x010138 4 1700 Res Ina Ena Vis xfilter Current status: Started 0x01013A 4 1700 Res Ina Ena Vis xfilter Applications: In Deny, Out Prompt 0x01013C 4 1700 Res Ina Ena Vis xfilter Websites: In Deny, Out Pass 0x01013E 4 1700 Res Ina Ena Vis xfilter Intranet: In Prompt, Out Pass 0x010140 4 1700 Res Ina Ena Vis xfilter ICMP(PING): Pass All 0x010142 4 1700 Res Ina Ena Vis xfilter High 0x010144 4 1700 Res Ina Ena Vis xfilter Current mode: Custom Mode 0x010146 4 1700 Res Ina Ena Vis xfilter Mode &Wizard 0x010148 4 1700 Res Ina Ena Vis xfilter Shell Embedding 0x010158 5 1700 Res Ina Ena Vis xfilter Shell DocObject View 0x01023C 6 1700 Res Ina Ena Vis xfilter Internet Explorer_Server 0x01014C 4 1700 Res Ina Ena Vis xfilter Status 0x01014E 4 1700 Res Ina Ena Vis xfilter Status 0x010160 3 1700 Res Ina Ena Hid xfilter #32770 0x010162 4 1700 Res Ina Dis Vis xfilter &Application 0x010164 4 1700 Res Ina Ena Vis xfilter I&ntranet 0x010166 4 1700 Res Ina Ena Vis xfilter IC&MP 0x010168 4 1700 Res Ina Ena Vis xfilter &Listen Ports 0x01016A 4 1700 Res Ina Ena Vis xfilter Conn&ections 0x01016C 4 1700 Res Ina Ena Vis xfilter &Clear 0x01016E 4 1700 Res Ina Ena Vis xfilter Scroll &off 0x010170 4 1700 Res Ina Ena Vis xfilter S&top 0x010172 4 1700 Res Ina Ena Vis xfilter &Find 0x010174 4 1700 Res Ina Ena Vis xfilter &Save 0x010176 4 1700 Res Ina Ena Vis xfilter List1 0x010178 5 1700 Res Ina Ena Vis xfilter SysHeader32 0x01017C 4 1700 Res Ina Ena Hid xfilter List1 0x01017E 5 1700 Res Ina Ena Vis xfilter SysHeader32 0x010182 4 1700 Res Ina Ena Hid xfilter List1 0x010184 5 1700 Res Ina Ena Vis xfilter SysHeader32 0x010188 4 1700 Res Ina Ena Hid xfilter List1 0x01018A 5 1700 Res Ina Ena Vis xfilter SysHeader32 0x01018E 4 1700 Res Ina Ena Hid xfilter List1 0x010190 5 1700 Res Ina Ena Vis xfilter SysHeader32 0x010194 4 1700 Res Ina Ena Vis xfilter Monitor - Applications 0x010196 4 1700 Res Ina Ena Vis xfilter Monitoring enabled,Scroll on 0x010198 4 1700 Res Ina Ena Vis xfilter Monitor - Applications 0x01019A 4 1700 Res Ina Ena Vis xfilter Monitor - Applications 0x0101C4 3 1700 Res Ina Ena Hid xfilter #32770 0x0101C6 4 1700 Res Ina Ena Vis xfilter Log - Applications 0x0101C8 4 1700 Res Ina Dis Vis xfilter &Application 0x0101CA 4 1700 Res Ina Ena Vis xfilter &Intranet 0x0101CC 4 1700 Res Ina Ena Vis xfilter IC&MP 0x0101CE 4 1700 Res Ina Ena Vis xfilter SysDateTimePick32 0x0101D0 4 1700 Res Ina Ena Vis xfilter SysDateTimePick32 0x0101D2 5 1700 Res Ina Ena Vis xfilter msctls_updown32 0x0101D4 4 1700 Res Ina Ena Vis xfilter SysDateTimePick32 0x0101D6 4 1700 Res Ina Ena Vis xfilter SysDateTimePick32 0x0101D8 5 1700 Res Ina Ena Vis xfilter msctls_updown32 0x0101DA 4 1700 Res Ina Ena Vis xfilter &Query 0x0101DC 4 1700 Res Ina Ena Vis xfilter &Clear 0x0101DE 4 1700 Res Ina Dis Vis xfilter &Back 0x0101E0 4 1700 Res Ina Dis Vis xfilter &Next 0x0101E2 4 1700 Res Ina Ena Vis xfilter Find 0x0101E4 4 1700 Res Ina Ena Vis xfilter &Save 0x0101E6 4 1700 Res Ina Ena Vis xfilter List1 0x0101E8 5 1700 Res Ina Ena Vis xfilter SysHeader32 0x0101EC 4 1700 Res Ina Ena Hid xfilter List1 0x0101EE 5 1700 Res Ina Ena Vis xfilter SysHeader32 0x0101F2 4 1700 Res Ina Ena Hid xfilter List1 0x0101F4 5 1700 Res Ina Ena Vis xfilter SysHeader32 0x0101F8 4 1700 Res Ina Ena Hid xfilter From 0x0101FA 4 1700 Res Ina Ena Vis xfilter -> 0x0101FC 4 1700 Res Ina Ena Vis xfilter 0/0 pages; 0/0 written 0x0101FE 4 1700 Res Ina Ena Vis xfilter &Text log 0x010200 4 1700 Res Ina Ena Vis xfilter &Expired log 0x010202 4 1700 Res Ina Ena Vis xfilter Log - Applications 0x010204 4 1700 Res Ina Ena Vis xfilter Log - Applications 0x0100D4 2 1700 Res Ina Ena Vis xfilter Filseclab Personal Firewall Profession 0x0100D6 2 1700 Res Ina Ena Vis xfilter Filseclab Personal Firewall Profession 0x010236 1 1784 Res Ina Ena Hid FilMsg Filseclab Message Center 0x0101F6 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101F0 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x0101EA 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010192 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01018C 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010186 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x010180 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01017A 1 1700 Res Ina Ena Hid xfilter tooltips_class32 0x01015C 1 1700 Res Ina Ena Hid xfilter Internet Explorer_Hidden 0x020096 1 1324 Res Ina Ena Hid MouseFix MouseFix 0x010090 1 992 Res Ina Ena Hid explorer Connections Tray 0x020082 1 992 Res Ina Ena Hid explorer Power Meter 0x030088 2 992 Res Ina Ena Vis explorer Power status 0x01008A 2 992 Res Ina Ena Vis explorer &Always show icon on the taskbar. 0x01008C 2 992 Res Ina Ena Vis explorer Show details for each &battery. 0x01008E 2 992 Res Ina Ena Hid explorer Static 0x030086 1 992 Res Ina Ena Hid explorer MS_WebcheckMonitor 0x010062 1 992 Res Ina Ena Hid explorer WorkerW 0x030034 1 992 Res Ina Ena Hid explorer WorkerW 0x050048 1 932 Res Ina Ena Hid nvsvc32 NVSVCPMMWindowClass 0x02004C 1 992 Res Ina Ena Hid explorer DDEMLEvent 0x020050 1 992 Res Ina Ena Hid explorer DDEMLMom 0x01007C 1 992 Res Ina Ena Hid explorer tooltips_class32 0x01006C 1 992 Res Ina Ena Vis explorer Program Manager 0x010072 2 992 Res Ina Ena Vis explorer SHELLDLL_DefView 0x010078 3 992 Res Ina Ena Vis explorer FolderView 0x03003A 1 992 Res Ina Dis Hid explorer M 0x03003C 1 992 Res Ina Dis Hid explorer Default IME 0x270240 1 300 Res Ina Dis Hid seamonke M 0x090268 1 300 Res Ina Dis Hid seamonke Default IME 0x130280 1 992 Res Ina Dis Hid explorer M 0x18027A 1 992 Res Ina Dis Hid explorer Default IME 0x0B0382 1 992 Res Ina Dis Hid explorer Default IME 0x0A0360 1 300 Res Ina Dis Hid seamonke Default IME 0x01015E 1 1700 Res Ina Dis Hid xfilter M 0x0100AA 1 1700 Res Ina Dis Hid xfilter Default IME 0x01023A 1 1784 Res Ina Dis Hid FilMsg M 0x010238 1 1784 Res Ina Dis Hid FilMsg Default IME 0x01009A 1 1324 Res Ina Dis Hid MouseFix Default IME 0x020084 1 992 Res Ina Dis Hid explorer Default IME 0x04002C 1 932 Res Ina Dis Hid nvsvc32 Default IME 0x010080 1 992 Res Ina Dis Hid explorer M 0x02004E 1 992 Res Ina Dis Hid explorer Default IME
If another window looses focus on account of the being closed, I think the taskbar receives the focus by default. I think technically, the taskbar is always the top window. [Edit] ...unless maybe some other window is set to "always on top", but I haven't experimented with that to find out. -
I found something that might help with the OP's problem, but did not test it. I don't mind the way Windows 7 behaves by default.
http://www.sevenforums.com/general-discussion/215607-how-do-i-get-top-most-window-alwa...ml#post1811615
PotPlayer window-in-window
By jaywalker32 in forum Software PlayingReplies: 1Last Post: 28th Oct 2014, 19:17 -
Win7 makes DVD corrupted when ejecting
By wolfgang_b in forum Authoring (DVD)Replies: 15Last Post: 10th Aug 2014, 04:52 -
Two Webcams In One Window
By frmys in forum Newbie / General discussionsReplies: 0Last Post: 13th Jul 2014, 23:38 -
Can't 'open in new window'
By Megahurts in forum ComputerReplies: 3Last Post: 15th Oct 2013, 23:13 -
Cubase6+Win7 64bit+RadeonX550 graphics - Video window is black - Why!??
By jouleskeys in forum Software PlayingReplies: 1Last Post: 1st Sep 2012, 06:12
