Results 1 to 10 of 10
  1. hey guys i have tried to search this forum and many others with no luck most are outdated topics with players from 2010
    what i would like is a blu-ray player that supports srt via usb
    i think most modern players have build in wifi but this is one of the key things i need as well
    i atm have a Sony BDP-BX59 and this one sure does not support it i have to convert files to make sub's work which im getting tired off
    Please help - Thank you very much
    Aug 2006
    LG Blu-Ray players have good support for SRT subtitles. Find a model that you like and download the manual from LG's webpage for that model. The manual will usually have a chart with information about the type of media files that can be played, and the associated subtiltes.
  3. I'm a Super Moderator johns0's Avatar
    canada
    Your sony supports srt subs,the thing is you have to merge the subs,no converting or re-encoding needed.
  4. are you talking about useing AVIaddXSubs. or something like that to merge the srt ? and will i have able to turn off the sub's when i dont wanna see them ?
    and Thanks Usually quiet this is what i was looking for i dont rly want to get a program to do anything to the srt file just wanna name them the same name and they work so ill take a look at the lg's
    canada
    I use mkvmerge to add srt subs,it outputs mkv files which can be xvid or h264 which your sony will work with.You can turn off the subs anytime you want.
  6. yea i have a problem with that one and i have seen many others have the same? cant fast forward or rewind the movie. maybe u can tell me why this happens or how to fix ?
    canada
    In mkvmerge you need to add a few command lines since they updated it so on older players it has that issue,the command lines you need to add are
    --engage no_cue_relative_position --engage no_cue_duration --disable-track-statistics-tags
    Just paste them in mkvmerge/muxing/add command line options.Then check the box where it says Save as default for new jobs.
    You can do this for other files that have this issue.Just remux them.
  8. i will give this a go Thank you very much this may save me from buying a new Blu-ray player will report back if it worked for me ^^
  9. works like a charm Thank you very much - i may still look for a new blu-ray player but now i dont have any rush for it !
  10. I'm a Super Moderator johns0's Avatar
    canada
    The only thing is with a new blu-ray player and movie you want to backup that has cinavia will cause you lots of grief,with my sony bdp-s380 it has no cinavia firmware installed on it since i didn't update it to the latest version which has it plus it plays all my backups with no problems.
    I had the same subtitle issue you had until i found i had to mux the srt into files,also had to do the command line with mkvmerge since it had no rw/ff and freezing,plus when i burn my mkvs i make sure i add a separate srt along with the muxed srt in case my next blu-ray player only reads separate srts.
