Hi,
I'm sorry I'm completely new to this tech thing and I'm freaking out a little because I have a deadline due tmr.
Its a stab at the dark but I'm keeping my fingers crossed if anyone has a solution.
I'm using a Panasonic X920, and have some video files on the SD card.
It doesn't show up as individual video files when plugged into the laptop just a generic AVCHD file (which I can open with quicktime; i'm on a mac btw)
So I open the files with Quicktime, hoping to then export it as movie files to physically save into my laptop (which I have done before)
But as one of the files was too big? (2hrs ish long) Quicktime crashed, and I think that f**ked up the encoding because now I can't seem to open any file after that one, including that.
I have the mts, xmp, cpi files but I know the encoding has f**ked up somewhere.
Does anyone know how I can fix this?
Much much much appreciated. TYSM
You're a bit behind the 8-ball with a mac, but you're also vague on details.
How are you connected to the mac, USB? What software are you using Quicktime X? Do you have FCPX which would make this task infinitely easier? Have you tried copying the entire structure of your SD card to the computer, not simply individual files?
A 2 hour + recording will necessarily involve spanned clips which requires proper software to interpret (FCPX, Premiere Pro, Avid Media Composer -- Panasonic's own software is not mac compatible.)
You probably haven't actually f**ked up any of your material yet -- but you're well on the way
it is, it now says it can't be played on this model on the camera, and when I plug in the SD card on the computer, the respective mts files says 0kb :/
That's not a good sign
Do not write anything to the card
Take out the card, reset the camera (look in your manual for the procedure), re-insert the card, then try again
If that still doesn't work, you're next step it to look at file recovery software options
corrupt .mts file (incorrect length)
By sandergoorden in forum Video ConversionReplies: 55Last Post: 30th Apr 2015, 08:56 -
Corrupt MTS files
By Curtis789 in forum Video ConversionReplies: 6Last Post: 21st Feb 2013, 13:37 -
Corrupt .MTS file
By Kajal in forum Video ConversionReplies: 2Last Post: 29th Sep 2012, 07:35 -
Lumix gh2 corrupt mts files
By ybjlus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 4th Aug 2012, 16:31 -
Possibly Corrupt MTS Filt
By sherman39 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 9th Jun 2012, 08:57
