You may wanna try to encode the audio and video seperately to MPG And then multiplex them with TMPGEnc...if that still does not work...try using a program to convert the WMV to WAV, and then try encoding it...those are just a few things i'd try!
Good Luck!
If I knew everything, I wouldn't be here....
WMV-HD Encoder?
By therock003 in forum Video ConversionReplies: 7Last Post: 14th Dec 2012, 13:54 -
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
How to convert DV to WMV using Windows Media Encoder
By Baldrick in forum User guidesReplies: 10Last Post: 5th Jan 2008, 01:35 -
Cant convert DV into WMV using Windows Media Encoder
By Viola123 in forum EditingReplies: 2Last Post: 2nd Dec 2007, 14:57 -
Stream to WMV without using harddrive? (windows media encoder)
By spanoj in forum Capturing and VCRReplies: 4Last Post: 20th Aug 2007, 07:37
