  1. Because of the better MPEG quality, i tried to convert AVI, captured with my MIRO DC10+ card, to MPEG with TMPGEnc. But i only see a black screen! Only audio is converted. Did i something wrong, the settings?
    Can somebody help me please?
    Nov 2001
    Central NY USA
    I believe it has to do with the proprietary codec. I had the same problem with my StudioPCTV. I simply used Virtualdub rather than the pinnacle capture software.
    Suds
    AIM: sudsbrewer@netscape.com
    YIM: sudsbrewer
    MSN: rpwinks@hotmail.com
    Opinions are like a**holes. Everybody's got one.
  3. Can you play the captured files with the Windows Media Player? If not, you don't have the needed codec installed. Try installing a mjpeg codec, that should make the AVI file readable in Windows Media Player and Tmpenc.
  4. I had the same problem.
    Check the x in the Environmental setting and under the VFAPI plugin, if you have the AVI2OPEN DML file reader checked, and with a higher priority than the others, you get a black screen.
    Try playing with the checks, uncheck all but one, and continue through the available checkboxes, then you will find the one that works.
    I am using DC10Plus, and I have no problems after I unchecked the above.
